" /> GVP8 and Composer Libraries for JSON - Genesys CTI User Forum
Author Topic: GVP8 and Composer Libraries for JSON  (Read 2885 times)
Offline clemouk
« on: March 05, 2012, 05:40:47 PM »
After deploying an application to IIS 7 on Windows Server 2008, I have noted the error below in the Windows Event Viewer - this is causing a HTTP 500 Server Error in the MCP logs. Effectively it doesn't seem to be able to find the DLLs in the "bin" folder; I cant find any reference in the Genesys documents that indicate this needs to be done as a separate process.
[b][i]Exception information:
    Exception type: HttpCompileException
    Exception message: d:\eloyalty\gvp.applications\voxfer\include\getWebRequestData.aspx(21): error CS0246: The type or namespace name 'JObject' could not be found (are you missing a using directive or an assembly reference?) [/i][/b]
Has anyone ever come across this before?
Lee
