" /> Genesys v7.x Desktop aplication - Genesys CTI User Forum
Author Topic: Genesys v7.x Desktop aplication  (Read 4094 times)
Offline Mat
« on: March 29, 2012, 09:49:57 AM »
Hi
I'm installing a new O.S windos 7 in our landtop and I can't install genesys aplications (CME, IRD,CCPulse) the versions are 7.x and the problem is the O.S isīnt compatible.
Can you hel me?
Offline Pyrahblandfords
Re: Genesys v7.x Desktop aplication
« Reply #1 on: March 29, 2012, 11:41:44 AM »
Hi
I had the same issue so just ran the apps from a virtual XP machine running on Win7 instead.
Regards
Steven
Offline Kevin S
« Reply #2 on: March 29, 2012, 12:40:07 PM »
Version 8 of the applications is Win 7 compatible.
For reporting (Data Modeling assistant), I believe there is a 7.6 version compatible, but I would refer you to release notes to confirm.
« Reply #3 on: March 29, 2012, 01:36:44 PM »
Hi Kevin
I've just tried to install v8.0.200.03 of CME on my Win7 machine and it's failed.
I checked the release notes and they say support is up to Vista.
Although as an alternative you could just run the web based Administrator to get around that issue.
I think it's the 8.1 clients onwards that are Win7 compatible.
Steven
Offline Steve
« Reply #4 on: March 29, 2012, 05:34:06 PM »
When I set up a Windows 7 client machine on our model, I simply copied the Config Manager directory from an XP machine. It would probably work with other clients too.
Offline Kevin S
« Reply #5 on: April 03, 2012, 06:01:28 PM »
Steven -
I stand corrected. I think I was focusing on CC Pulse, as we have been trying to find a 8.0 version of it we're happy with.
Of course, check release notes or any other published compatibility guide for clarification.
Offline Mat
« Reply #6 on: April 09, 2012, 03:07:23 PM »
I solved my problem instalig all de apps in Windows 7 run as  Windows XP compatibility mode Service pack 3, with Service pack 2 mode compatibility don't run.
