" /> Purge for DM DB? - Genesys CTI User Forum
Author Topic: Purge for DM DB?  (Read 4650 times)
Anthony
Purge for DM DB?
Has anybody develop a stored procedure to purge data from the CC Analyzer historical tables?
Purge for DM DB?
drop user will do the trick :)
Interesting question, because I was trying to do it as well, and right away I thought of ETL Assistant. You can specify how long you want to keep the data for, and when you would want to truncate it.
Anthony
Purge for DM DB?
Thanks...
Purge for DM DB?
Any time :) Tell me if there is anything else I can help you with.
Marked as best answer by on July 17, 2025, 01:38:35 PM
Beancurd
Purge for DM DB?
I believe Genesys have a utility to purge the data.Rumour has it it's on the Reporting CD I'm not in a position to check at the moment.
