" /> GVP processes max log size - Genesys CTI User Forum
Author Topic: GVP processes max log size  (Read 3415 times)
Offline dnib
« on: August 08, 2012, 10:01:15 AM »
Hi guys!
I am trying to increase the log file size for GVP 7.6 processes above 257KB as described on the Genesys support forum (below you can find link) but the changes have no effect.
http://solutionsearch.genesyslab.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=12434&sliceId=2&docTypeID=DT_QUESTIONANDANSWER_1_1&dialogID=23768449&stateId=0 0 23766621
In EMPS I see the new attribute ( MaxLogSize ) but the log file is still 257KB.
Please help me with this as I want to increase the logging level to debug.
Thank you,
Daniel
Re: GVP processes max log size
« Reply #1 on: August 08, 2012, 03:08:35 PM »
Have you restarted it?
Offline dnib
« Reply #2 on: August 09, 2012, 05:49:20 AM »
Yes, after I added the new attribute. I restarted the process and no difference. After that I restarted watchdog and the same.
Offline dnib
« Reply #3 on: August 09, 2012, 12:52:40 PM »
it seems that if I add a the new attribute LogMaxSize and restart Watchdog, the gvp.ini file is not being modified accordingly. So no change in configuration I ...
« Reply #4 on: August 09, 2012, 04:09:37 PM »
Maybe a bug on the version...I'd open a support ticket directly my friend
Offline postx
« Reply #5 on: August 16, 2012, 09:33:19 PM »
what value does the paramter "localconfig" in your gvp.ini have?
Offline dnib
« Reply #6 on: August 22, 2012, 01:56:37 PM »
when I try to do changes through EMPS the localconfig is set to 0
