" /> How to pass KVP from Avaya T-server to GVP - Genesys CTI User Forum
Author Topic: How to pass KVP from Avaya T-server to GVP  (Read 4195 times)
Offline Genesys123
« on: August 20, 2012, 05:04:44 PM »
I am having below sceneario, I need to transfer the call to IVR Applicaiton (GVP). When i do trasnfer to SIP Trunk , all KVPs are missing so my IVR application is not working.
I did 2 test,
1. I have transferred call to Trunk DN from IWS (T-server DN) ,but there is no KVp
2. I have tranferred to SIP RP then T-Route to IVR ,i can see KVP passing from SIP server  but IVR application is not working getting incall Reject Error.
Any solution?
Re: How to pass KVP from Avaya T-server to GVP
« Reply #1 on: August 20, 2012, 05:10:05 PM »
Which GVP?? 7.6? 8.x?
Which is your configuration? ISCC done?
SIP Server headers mapped if using 8?
Check the posts done already
Offline Genesys123
« Reply #2 on: August 20, 2012, 06:00:45 PM »
Yes, ISCC configured. we are using 8.x.
SIP header Mapping? I didn't understand please give me an example.
« Reply #3 on: August 20, 2012, 07:02:24 PM »
I assume that you SIP Server was installed as part of GVP deployment. Based on that assumption, call flow will be:
data path: TServer Avaya --- (ISCC) ---> SIP Server --- (UserData to SIP header mapping) ---> GVP
voice signalling path: Avaya --- (AES SIP trunk) ---> SIP Server ---> (SIP trunk) ---> GVP
It is possible to have different deployment but the one described above is kinda standard one.
