" /> Interactive Insights deployment - Genesys CTI User Forum
Author Topic: Interactive Insights deployment  (Read 4023 times)
Offline smile
« on: August 27, 2012, 07:34:14 PM »
deployment guide of GI2 plus number of download items on support made me dizzy...
guide says: "At your option, however, you can also install BOE silently, during the installation of Interactive Insights."
but from representatives and download i have:
- Genesys Interactive Insights (40mb)
- BOE server & client
- crystal reports
- Genesys Interactive Insights CD (200mb)
what is "Genesys Interactive Insights BOE Server Windows"? is it equal to BOE server?
do i need to install BOE & CMS manually first and just after than install Interactive Insights?
what is the simplest way to install gi2? is there exist some kind of all-in-one package?
Re: Interactive Insights deployment
« Reply #1 on: August 29, 2012, 11:35:21 AM »
You can install BOE manually at first and then install GII package or you can install all-in-one - in install process you install BOE at first,and then GII. You can deploy GII files automatically via installer or manually,via copy GII files to the BOE server.
Yes,both are same.
Offline smile
« Reply #2 on: August 29, 2012, 12:04:32 PM »
Thank you! Could you please point out which package should i use for all-in-one installation?
« Reply #3 on: August 29, 2012, 12:30:26 PM »
If you install GII from standard Genesys package,so you can install BOE during the installation -> you set installation folder and folder with install source of BOE.
Offline smile
« Reply #4 on: August 29, 2012, 12:37:25 PM »
ok, i'll try this.
« Reply #5 on: August 29, 2012, 12:42:23 PM »
I do that now and all works fine,BOE and GII has been installed correctly and GII files are deployed automatically to the BOE server.
Offline smile
« Reply #6 on: August 29, 2012, 01:17:47 PM »
CMS deployed automatically during BOE installation or i'll need to deploy it manually first?
