" /> stat server app installation on WINDOWS 2008 with 64 bit - Genesys CTI User Forum
Author Topic: stat server app installation on WINDOWS 2008 with 64 bit  (Read 3673 times)
Offline rakesh.jha8408@gmail.com
« on: September 24, 2012, 10:56:22 AM »
I am trying to install stat server 8.1.000.12 in windows 2008 64 bit environement. But i m seeing that default path is in the folder Progrma files[x86] which indicates it is 32 bit application installed and even on task manager in sees with the tag as 32. Please let me know how i can install stat server with 64 bit application
Re: stat server app installation on WINDOWS 2008 with 64 bit
« Reply #1 on: September 24, 2012, 11:18:48 AM »
And is install package determined for 64 bit Windows?
« Reply #2 on: September 24, 2012, 11:25:41 AM »
I downloaded version 8.1.000.12. in read me file i m seeing its supported 32 bit and EM64T bit in the read me file
« Reply #3 on: September 24, 2012, 12:16:20 PM »
or how i can download a 64 bit installer for stat server version 8.1.000.12?
« Reply #4 on: September 24, 2012, 12:49:11 PM »
StatServer component for Windows 2008 64 bit does not exist..Only for UNIX systems
« Reply #5 on: September 24, 2012, 03:27:39 PM »
You must stick to limits of the application. 64bit is not supported on Windows so you must install it on a 32bit server
