" /> No outbound port available in GVP SSG Logs - Genesys CTI User Forum
Author Topic: No outbound port available in GVP SSG Logs  (Read 4121 times)
Offline thinkb4umail
« on: October 10, 2012, 02:32:11 AM »
I see the below error in the SSG logs, and cannot make outbound calls using GVP 8.1
"There are no outbound ports available for Tenant[Resources]. Outbound calls will not be initiated."
Please suggest as to what needs to be configured to make this work.
Thanks.
Offline bublepaw
Re: No outbound port available in GVP SSG Logs
« Reply #1 on: October 10, 2012, 08:24:02 AM »
Did You try searching for "There are no outbound ports available" on Genesys Tech support - first result will give You answer. Hint - in has something to do with Trunk Group object configuration
« Reply #2 on: October 11, 2012, 05:20:17 PM »
That pretty much did it!
I added the Resources Trunk Group, and got my application working.
Thanks!
Offline naviat
« Reply #3 on: January 17, 2013, 10:43:25 AM »
hi all,
I have the same problem but i don't have genesys lab account. Anyone can send me the guide for Resoure Trunk Group SSG. Thanks so much :)
« Reply #4 on: January 17, 2013, 11:45:26 AM »
How to create TG you usually know,so..
You have to configured following options:
Contact - sip:IP_RM:port
cpd-capability - mediaserver
event-ringing-on-11trying - true
make-call-rfc3725 - 1
refer-enabled - false
request-uri - depend on your deployment - generally sip:msml@ip_RM:port;gvp-tenant-id=tenant_name
ring-tone-on-make-call - false
subscription-id - tenant name
Offline naviat
« Reply #5 on: January 21, 2013, 02:55:32 AM »
Thanks Kubig  ;D
