" /> DMA in Windows 7 - Genesys CTI User Forum
Author Topic: DMA in Windows 7  (Read 3494 times)
Offline PFCCWA
DMA in Windows 7
« on: October 31, 2012, 04:10:03 PM »
I know there are no plans to release DMA for Windows 7 however is there a workaround in installing it on that operating system.
thanks,
Re: DMA in Windows 7
« Reply #1 on: October 31, 2012, 04:58:38 PM »
I tried the compatibility mode but crashes from time to time...I prefer to put a VM on XP and work there or connect directly to the server
No W7 version yet?? Will check just in case
« Reply #2 on: November 01, 2012, 06:58:29 AM »
I am using DMA on Windows 7 daily and I have not problems..
Offline imaki
« Reply #3 on: November 01, 2012, 08:45:13 AM »
So how did you manage to install it then?
By the way, Windows 8 do not have the XP mode, so I hope, that Genesys will make a DMA that can be installed to new OS's. I cant see why it cant be allowed to be installed on Win7 when you can install it on Win2008 already..
Offline imaki
« Reply #4 on: November 02, 2012, 06:27:48 AM »
Ok, now I got it. I have Win7 64-bit, so I needed to use win2003 sp1 compatibility mode to install DMA.. I previously tried Win XP, Win 2008, Vista so I thought that should cover all choices.
