" /> ETL error when moving Config Server - Genesys CTI User Forum
Author Topic: ETL error when moving Config Server  (Read 4274 times)
Offline Dudzy
« on: November 27, 2012, 01:11:04 AM »
Can anyone assist, moving development environment to a new set of HOSTS, ETL (DataMart) ETL_Tracking is producing an error.
ETL_Tracking*:* 12/11/27 12:05:01.232 EST 16252928 main INFO Starting ConfigServer Synchronization
ETL_Tracking*:* 12/11/27 12:05:01.310 EST 16252928 main INFO Connecting to ConfigServer confserv[melgtslab05:2020] as 'ETL_Proxy'
ETL_Tracking*:* 12/11/27 12:05:03.216 EST 16252928 main INFO Getting Skills from ConfigServer confserv[melgtslab05:2020]
ETL_Tracking*:* 12/11/27 12:05:05.294 EST 16252928 main INFO Getting Agents from ConfigServer confserv[melgtslab05:2020]
ETL_Tracking*:* 12/11/27 12:05:08.169 EST 16252928 main EXCEPT Error Checking ConfigServer for TableRowObject[id: UKey[name: UKey#49'CONFSERVER_ID':1], values: {'CONFSERVER_ID':1, 'CONFSERVER_NAME':confserv, 'CONFSERVER_HOST':melgtslab05, 'CONFSERVER_PORT':2020}][ExcptMsg: null]
ETL_Tracking*:* Stack Trace:
ETL_Tracking*:* java.lang.NullPointerException
ETL_Tracking*:* at com.genesyslab.Infomart.ConfReport.ConfigServerRef.checkAgents(ConfigServerRef.java:200)
ETL_Tracking*:* at com.genesyslab.Infomart.ConfReport.ConfigServerRef.CheckObjects(ConfigServerRef.java:94)
ETL_Tracking*:* at com.genesyslab.Infomart.ConfReport.Application.start(Application.java:279)
ETL_Tracking*:* at com.genesyslab.Infomart.ConfReport.Application.main(Application.java:242)
ETL_Tracking*:* 12/11/27 12:05:08.169 EST 16252928 main INFO Finished ConfServer Synchronization
Offline Dudzy
Re: ETL error when moving Config Server
« Reply #1 on: November 27, 2012, 02:09:41 AM »
update: checking previous log files pre Config Server move, the error was already in logs files, so moving that can be eliminated.
Any assistance would be appreciated
« Reply #2 on: November 27, 2012, 04:23:48 AM »
Go to ETL tables and change the DBID value on properties table
Offline Dudzy
« Reply #3 on: November 27, 2012, 05:40:16 AM »
Hi cavagnaro
Not sure which table you are referring to directly
With DataMart/ETL schema there is only one table with "properties "as a name  DM_PROPERTIES
With the ODS schema, there is a OL_DB_PROPERTIES table
Are you able to be a little more specific ?
Dave
Offline borkokrz
« Reply #4 on: November 27, 2012, 08:14:50 AM »
Check if DM_KEY\brand field in DM_PROPERTY equals OL_KEY\brand in OL_DB_PROPERTIES.
I've seen java.lang.NullPointerException in one scenario. When using old ETL with newest confserv 8.0+. In this config when person is configured with one of the ranks : Genesys Administrator/Interaction Workspace) you will have similar error. Upgrade ETL to 7.6.000.17+ or make sure that ETL don't have access to this persons. AFAIR this can also occur with persons with over 20 ranks assigned or when using japanese character encoding.
« Last Edit: November 27, 2012, 08:24:37 AM by borkokrz »
Offline Adam G.
  • Still Gorgeous.......
« Reply #5 on: November 27, 2012, 08:38:25 AM »
Check the table CONFIG_SERVER in your Datamart.
Offline Dudzy
« Reply #6 on: November 30, 2012, 04:33:39 AM »
thanks guys, etl upgrade to latest version resolved.
