" /> IWS : How to show Origin and Queue in the Case Data section in the History - Genesys CTI User Forum
Author Topic: IWS : How to show Origin and Queue in the Case Data section in the History  (Read 2812 times)
Offline alaint
I have a question about IWS.  In interaction window, my "Case Information" section present the History information like : Origin and Queue.  Always in Interaction Window, when I go in the "History" tab of the "Contact" section and I look at the "Case Data" section, I dont see the same thing.  The Origin was not there.  We have the need to see the Origin in the history tab.  Is there a way to do that?
Thanks you
Alain
I dont know why, I cant attach a 160k jpg...
You can't attach even a 1K file :D it is disabled, try an external host server
I think that with default options it is not possible. So,you can save requested information to UCS DB and next fill these parameters into history tab in IWS,and you will see what you want.
Offline alaint
Thanks you.
