" /> Changing in Skills in GA - Genesys CTI User Forum
Author Topic: Changing in Skills in GA  (Read 3621 times)
Offline wickywick
« on: January 23, 2013, 11:36:34 PM »
Hi all,
I was wondering if anyone knew if it was possible to change agent skills by using XML script.
I am in the process of doing a complete overhaul of my contact center and would like to know if anyone else has done this in the past or if it possible.
Thanks for you assistance.
Re: Changing in Skills in GA
« Reply #1 on: January 24, 2013, 01:32:47 AM »
Executed by what? You could create a software with PSDK and then read your XML file and do what you need
Offline wickywick
« Reply #2 on: January 24, 2013, 01:39:54 AM »
Thanks for your reply, honestly, I hadn't thought it through that far as to what I was going to use for execution. Wanted to find out if this was possible first.
I will investigate in to SDK tool, we don't currently use it, there were talks about getting the functionality.
On a different path, would you know if there was a universal standard for dropped call %.
« Reply #3 on: January 24, 2013, 02:13:46 AM »
Dropped calls? Outbound? No sir, will depend totally on many variables on your environment like type of dialing, dialing power, number of agents ready/not ready, average talk, hour of dialing, filters...etc.
Offline wickywick
« Reply #4 on: January 24, 2013, 03:18:07 AM »
no problem, thanks for your input cavagnaro, just thought I'd put it out there. We operate in an inbound/outbound environment a fairly large operation with about 400 agents spread throughout the day.
Offline Adam G.
  • Still Gorgeous.......
« Reply #5 on: January 24, 2013, 09:40:30 AM »
There is a CME plugin called Configuration Import Wizard that can be purchased from Genesys that lets you import configuration infomation stored as XML.
W
Offline Kevin S
« Reply #6 on: January 25, 2013, 05:40:45 PM »
I know there is also the import functionality within GA, but I've only used it with CSV files. Maybe convert the XML to a CSV?
« Reply #7 on: January 25, 2013, 06:26:17 PM »
He wants to modifiy not create new objects, as far as I remember the import wont work for duplicated or already existing objects, correct me please if I'm wrong
Offline Kevin S
« Reply #8 on: January 25, 2013, 07:23:58 PM »
In newer versions (I know it's in 8.1 ) there is the option to import updates to existing objects.
