" /> Ringback tone on SIP - Genesys CTI User Forum
Author Topic: Ringback tone on SIP  (Read 11481 times)
« on: February 08, 2013, 11:51:24 AM »
Hi all,
have anybody experience with configuring ringback tone on SIP server R8.1? I would like to play to the customer a ringback tone when the call ringing on agent,but currently customer hears silence.
thx
Offline bublepaw
Re: Ringback tone on SIP
« Reply #1 on: February 08, 2013, 11:59:18 AM »
There is no nice solution to this request - what I usually do is I configure treatment-continous = true which causes SIPS to keep playing last music from strategy when customer is ringing on the agent extension - at least customer is not hearing silence. It is in theory possible to write strategy in such way that as last step before sending call to agent we start playing ringback but this requires decomposing Selection block.
« Reply #2 on: February 08, 2013, 12:03:14 PM »
Yes,you are right. I know about "solution" that you have desribed,so I am just wondering if there exists any "pure" solution
Offline Timur Karimov
« Reply #3 on: February 08, 2013, 01:07:48 PM »
Playing the ring tone throw SIP-PBX connection - it's a little complicate problem. For example - right choice to source of the ringing tone. In SIP v.8.1 we have the sip-ring-tone-mode options which describe the sip server strategy for choice the ringing source (internal or from treatmeant device like the SM) . Did you try to change the default mode?
Offline bublepaw
« Reply #4 on: February 08, 2013, 01:26:13 PM »
I can confirm that sip-ring-tone-mode=1 should solve problem (at least on my system)
« Reply #5 on: February 08, 2013, 01:51:54 PM »
Unfortunately, after change to value 1 nothing has been changed. I still hear silence.
Offline GMG
  • GCP CIV 8X
« Reply #6 on: February 09, 2013, 05:33:59 PM »
You can place a bell block, before targeting the call to a target.
This option will work when target is ready to take the call.
But Option gets failed when no agent is available to take the call and Busy treatment applied.
« Reply #7 on: February 11, 2013, 07:39:39 AM »
Yes, I can do it,but it is not pure solution and does not meet my needs. I know that this need is standard solve/make on GW site,but for internal needs would be great when the SIP server give ring-back
« Reply #8 on: February 11, 2013, 10:17:44 AM »
You caller does't hear ring-back in any scenarios? I mean direct call to agent DN, call throw RP with strategy, trasfer call between agent DN ?
« Reply #9 on: February 11, 2013, 12:24:17 PM »
I mean for example direct internal agent calls and internal calls to a RP,which routed the call afterward on agent.
« Reply #10 on: February 11, 2013, 01:12:19 PM »
Please show you sip server config options and dn options too. Also would be great if you could give a description of CC network environment (include used gateway and agent phone)
« Reply #11 on: February 11, 2013, 01:22:40 PM »
These information are unrelevant,because I want/need ringback tone on internal calls,ie. on Genesys solution. We are using IWS as a agent application,no hard-phone. GW is too out,because internal calls does not linked over GW.
« Reply #12 on: February 11, 2013, 02:51:58 PM »
Well, ok. But what about you sip server config? DN options?
« Reply #13 on: February 12, 2013, 01:15:45 PM »
Which options do you want to see? I have deployed SIP on my LAB server,so the configuration for DN and SIP is "default" with a few exception.Behavior is still same,no ringback tone
Offline smile
« Reply #14 on: February 12, 2013, 04:22:06 PM »
Kubig, check urs options give_treatment and compat_treatments. it depends on environment, i turned it off. and sip-ring-tone-mode=1 is relevant as well.
