" /> Once again User Data From SIPS to GVP - Genesys CTI User Forum
Author Topic: Once again User Data From SIPS to GVP  (Read 4136 times)
Offline Kirill
« on: February 20, 2013, 03:44:13 PM »
Hello!
Sems like I have a problem with User Data distribution from SIP Server to GVP.
SIP Server 8.1.3
GVP 8.1.5
I'am using USR's Play Application block with vxml application address in {s}APP_URI parametr.
Also I have configured GVP Voice over IP Service DN with userdata-map-fliter=* ,address of Resource Manager in contact field and service-type=application
Default vxml application is configured for the tennant.
Sip Server option userdata-map-trans-prefix=X-Genesys-
Both MCP and Gateway Resource Groups configured for resource Manager.
When I call to the Routing Point DN I can hear the vxml application, but I can see in the SIPS log that no User Data sent from SIPS to GVP.
Can anyone help me, what have I missed?
Re: Once again User Data From SIPS to GVP
« Reply #1 on: February 20, 2013, 08:40:27 PM »
Did you set any KVP(UserData) for Application block to sent to GVP?
Offline Kirill
« Reply #2 on: February 21, 2013, 07:31:02 AM »
O, I might have missed something.
I have added MultiAttach block in routing strategy and now I can see all the Udata from that block in GVP, but I thougth that SIPS would sent all the UData to GVP if I use  userdata-map-fliter=* option.
In any case that is good enough for me right now.  Kubig thank you for good advise.
Best regards.
« Reply #3 on: February 21, 2013, 12:58:27 PM »
Which attach data? hehe, you need first to attach data, which is USERDATA, not the same as default data like CONNID for example
Offline Kirill
« Reply #4 on: February 21, 2013, 01:09:26 PM »
Yes, already got it, thanks.
« Reply #5 on: February 21, 2013, 02:22:38 PM »
What says doc or Genesys Experts?
