" /> Config clients(CME, IRD,IWS) gets hang suddenly & start working after reboot - Genesys CTI User Forum
Author Topic: Config clients(CME, IRD,IWS) gets hang suddenly & start working after reboot  (Read 4204 times)
Offline Sundar
We have installed primary & secondary config server 8.1.200.17. The clients of config servers like CME, IWS, IRD, CCPulse gets hang suddenly. If i reboot the configdb server & config server, then its started working for some time.
When i check the config server logs, i found "Total number of clients:" is continuously increasing. Once it reach around 4200, then config clients are stop working.
I have configured ADDP connection to message server & siptservers.
[b]Also i found following error in the config server logs.[/b]
10:58:38.217 Trc 04542 Message MSGCFG_SERVERPROTOCOL sent to 3704 ( '')
  attr: SATRCFG_PROTOCOL            value:  "CfgProtocol 5.1.3.78"
  attr: IATRCFG_REQUESTID          value:  15954
10:58:38.232 Trc 04541 Message MSGCFG_CLIENTREGISTER received from 3704 ( '')
  attr: SATRCFG_PROTOCOLEX          value:  "CfgProtocol 5.1.3.78"
  attr: SATRCFG_PROTOCOL            value:  "CfgProtocol 5.1.3.54"
  attr: SATRCFG_USERPASS            value:  "******"
  attr: SATRCFG_USERNAME            value:  ""
  attr: SATRCFG_APPPASS            value:  ""
  attr: SATRCFG_APPNAME            value:  "confserv"
  attr: IATRCFG_APPTYPE            value:  21 [ConfigurationServer]
  attr: IATRCFG_REQUESTID          value:  15955
10:58:38.232 Std 23500 Configuration Server Error : Error  [CFGAppSecurityViolation], object [CfgApplication], property [DBID] Description Application name is prohibited to login
10:58:38.232 Trc 04542 Message MSGCFG_ERROR sent to 3704 ( '')
  MSGCFG_ERROR
  attr: IATRCFG_ERRORCODE          value:  2230535
  attr: SATRCFG_DESCRIPTION        value:  "Application name is prohibited to login"
10:58:38.232 Trc 04520 New client 3708 connected
10:58:38.232 Trc 24300 Extended info : New client [3708] connected, protocol [cfglib]
10:58:38.232 Total number of clients: 733
10:58:38.232 Trc 04520 New client 3712 connected
10:58:38.232 Trc 24300 Extended info : New client [3712] connected, protocol [cfglib]
10:58:38.232 Total number of clients: 734
10:58:38.232 Trc 04541 Message MSGCFG_GETSERVERPROTOCOL received from 3708 ( '')
  attr: IATRCFG_SECURELIBRARY      value:  1
  attr: IATRCFG_REQUESTID          value:  1861
10:58:38.232 Trc 04542 Message MSGCFG_SERVERPROTOCOL sent to 3708 ( '')
Anyone pls help me to find the issue.
Regards
Sundar.k
« Last Edit: March 05, 2013, 12:32:30 PM by Sundar »
At first is important to find what application/component makes a lot of request to the confserv. It is OS limit for maximum number of connection.
Offline vjicecool
Deos your config server host meets genesys requirements?
What are other servers installed in the config server host?
Offline Sundar
The issue is that, multiple confser.exe process was running in TASK-MANAGER.  After kill the services, its starts working.
Sorry for the late reply..!!
Offline hsujdik
Have you considered using Configuration Server Proxy? By your post, I understand that all applications are authenticating and requesting configurations on Configuration Server Master.
