" /> Genesys CTI compatibility with SFDC - Genesys CTI User Forum
Author Topic: Genesys CTI compatibility with SFDC  (Read 4217 times)
Offline water235
« on: March 06, 2013, 12:55:09 PM »
Hi Friends,
Can anyone throw more light on the integration aspects of Genesys CTI with Sales Force CRM? I understand that there is no readymade GPlus adaptor available for Sales Force. If we need to build a connector on our own, what should be our approach and how difficult / easy is it?
Any pointers would be helpful and greatly appreciated!
Re: Genesys CTI compatibility with SFDC
« Reply #1 on: March 06, 2013, 01:20:56 PM »
You will need Genesys PSDK and develop your own integration on whatever you would need...
How hard? Depends on your skills and requirements
Offline rpenney
« Reply #2 on: March 07, 2013, 06:13:03 AM »
I believe there are companies who develop and sell SaleForce adapters, can't think of the name at the moment but I found them via a google search.
I cannot tell you if they are any good as I haven't used any.
Offline Fra
« Reply #3 on: March 12, 2013, 09:55:47 AM »
[quote author=water235 link=topic=7701.msg33285#msg33285 date=1362574509]
Hi Friends,
I don't think there's an out-of-the-box GPlus adapter, however, I suggest you contact Genesys to investigate what their new product effectively does: http://www.genesyslab.com/cloudconnect/index.aspx.
Fra
