" /> Preview Duration - Genesys CTI User Forum
Author Topic: Preview Duration  (Read 3330 times)
Offline PFCCWA
Preview Duration
« on: June 05, 2013, 11:06:58 AM »
I have noticed it is possible to report on Preview Duration - that is the amount of time (and assuming average) an agent spends 'reviewing' a record in preview dialling mode using Infomart.
But is this possible using ccpulse / CCA?
I cant find documentation within the solution search so think it may be functionality on ICON DB only.
I tried this statistic in statserver without success:
[TotalTimePreviewRecords]
Category=TotalTime
MainMask=UserEvent
Objects=RegDN, Agent, Place, GroupAgents, GroupPlaces
Subject=DNAction
[filter]
PreviewRecords=PairExist("GSW_USER_EVENT", "PreviewRecord")
The equivalent for total number works fine.
thanks.
Re: Preview Duration
« Reply #1 on: June 05, 2013, 12:59:29 PM »
And what about OCCExtension for StatServer?
Offline PFCCWA
« Reply #2 on: June 05, 2013, 03:30:54 PM »
Cant see any related statistics within the OCCExtension?..
We want to determine how long an agent previews a record from the point it is requested to the next action ie connect to dial or cancel/reject..
Offline minuteman
« Reply #3 on: June 18, 2013, 11:14:06 PM »
UserEvent is a momentary action (no duration), so time-aggregating categories cannot be used with such a MainMask.
Offline G3n35Y5
« Reply #4 on: June 19, 2013, 04:32:20 AM »
Hi PFCCWA,
Same is possible in case of customized GAD. You may introduce a key K whose value is set to some value e.g. 'A' the moment agent starts previewing a record. The moment agent clicks on button to make call, the value of this key K should change to value 'B'. You can then capture preview duration by using a filter for key K with the statistic.
