" /> IWS Customization - Hide/Remove Consultation Button - Genesys CTI User Forum
Author Topic: IWS Customization - Hide/Remove Consultation Button  (Read 5224 times)
Offline yaredsha
« on: June 10, 2013, 03:22:26 PM »
can someone tell me what is the best way to remove/hide the consultation button on the Team-communication window?
[img]http://www5.picturepush.com/photo/a/13286033/img/13286033.png[/img]
Thanks.
Re: IWS Customization - Hide/Remove Consultation Button
« Reply #1 on: June 10, 2013, 04:20:39 PM »
Don't remember but maybe on the Roles itself there is an option to doesn't allow it
Offline yaredsha
« Reply #2 on: June 10, 2013, 06:01:08 PM »
This was also what I expected but unfortunately it seems there is no Role to enable/disable parts of the team communicator functionality, i.e. in this case consultation. There is only "Team Communicator - Can Use" Role, with which it is possible to enable/disable the whole team communicator functionality (both transfer and consultation) but not part of it. May be there is a programmatic way of simply removing a button.
Offline Timur Karimov
« Reply #3 on: June 16, 2013, 09:22:17 PM »
Hi there
you can't change standart feature button by role. It's can be made only by rewriten toolbar by you one code.
WBR Tim
« Reply #4 on: June 16, 2013, 10:14:29 PM »
Not trying to change the button behaviour, just hide it...by roles was logic as it can disallow as well other buttons
Offline yaredsha
« Reply #5 on: June 17, 2013, 09:25:25 AM »
Thanks guys,
I ended up replacing the view with my own view. That means, I also had to replace the "done" button and its functionality. Somehow too much effort for being able to just hide a button.
« Last Edit: June 17, 2013, 03:42:31 PM by yaredsha »
« Reply #6 on: June 17, 2013, 12:03:29 PM »
Sorry Cav, but if you disallow it by role  - button will be still show in toolbar
