" /> 3rd Party Application Server Template - Genesys CTI User Forum
Author Topic: 3rd Party Application Server Template  (Read 3779 times)
Offline mumtazalam2k
« on: June 19, 2013, 06:09:04 PM »
Where can I find this 3rd Party application server template as this is not available in my downloads of GVP 8.1.6?
I need to use this for SIP HA setup.
Secondly the docs of genesys describes the HA setup steps using some Config Manager tool instead of GA, is this mandatory or GA can be used itself for SIP HA setup, if yes will there be any add on steps or other steps reqd.
Re: 3rd Party Application Server Template
« Reply #1 on: June 19, 2013, 06:40:37 PM »
GA can do all what CME can do.
« Reply #2 on: June 20, 2013, 04:52:00 AM »
how can i create applications of type 3rd party application server template?
i do'nt know where / which is 3rd party application server template
« Reply #3 on: June 20, 2013, 05:20:52 AM »
On Templates folder create a new one, select 3rd party and then create the App...if memory doesn't fails...
« Reply #4 on: June 20, 2013, 05:49:08 AM »
Yep, Cav is right...for Third Party Server you need not necessary use template, there is no advantage, because Third Party Server application object does not contain predefined options.
