" /> Showing Not Ready instead of Not Ready After Call Work in GAD - Genesys CTI User Forum
Author Topic: Showing Not Ready instead of Not Ready After Call Work in GAD  (Read 2253 times)
Offline gzooby
  • Software Engineer at Telefax S.A.
Hi!
Having a problem with GAD. Some agents, when selecting state "Not Ready - After Call Work" , GAD is showing "Not Ready" state. If they select one of the other Not ready customized states it works fine, but not with after call work state. However, in CCPulse, when the agent selects Not Ready After Call Work State (showing only "Not Ready" in GAD) it shows the agent in the correct state (Not Ready After Call Work (the pencil))
Any clues for attacking this problem?
Thank you a lot!
Re: Showing Not Ready instead of Not Ready After Call Work in GAD
« Reply #1 on: July 30, 2013, 02:05:31 PM »
What exactly version of GAD are you using?
Offline gzooby
« Reply #2 on: July 30, 2013, 02:46:54 PM »
The version of GAD is 7.6.401.04
