" /> Upgrading T-Server 7.6 to 8.x - Genesys CTI User Forum
Author Topic: Upgrading T-Server 7.6 to 8.x  (Read 2504 times)
ryau86
« on: January 01, 2014, 03:05:25 AM »
Hi All,
I currently have a 7.6 environment, however to support the new PBX, I need to upgrade the T-Server to 8.x.
If I upgrade T-Server 7.6 to 8.x, are there any other Genesys components that require mandatory upgrading?
Thank you.
Marked as best answer by on Today at 08:58:37 PM
Offline genesysguru
    • Genesys Guru Blog
Re: Upgrading T-Server 7.6 to 8.x
« Reply #1 on: January 01, 2014, 12:36:40 PM »
  • Undo Best Answer
  • As usual you would need to check the relevant documentation e.g. Migration Guide - Chapter 20 "Introduction to T-Server Migration"
    It might be wise to upgrade to framework 8.1 but I suspect as straight T-Server upgrade would be fine in isolation. You might need to check your license file since I seem to remember licensing changes from 7.x to 8.x
    Hope this helps.
