" /> Benefit of Config Server Proxy - Genesys CTI User Forum
Author Topic: Benefit of Config Server Proxy  (Read 2635 times)
Offline PFCCWA
« on: January 17, 2014, 08:44:01 AM »
We have HA platform v8 and use config server primary/backup.
However recently when we lost framework host, applications such as GAD failed to connect with backup config server.
I think the issue is failure for config server backup to become primary correctly.
but it has been recommended we use config server proxy however not such what the benefit would be?
We are a single tenant environment.
thanks.
Re: Benefit of Config Server Proxy
« Reply #1 on: January 17, 2014, 09:18:58 AM »
There are lots of benefits - ie:
- reduce number of client's connection to the master configuration server
- reduce load given by read request by clients (all components which needn't write object have to be connected via proxy)
- if configuration server goes down, all clients connected to the proxy are without any depends
Offline MarkComplete
« Reply #2 on: January 17, 2014, 04:27:17 PM »
Kubig is absolutely correct. There are many benefits to using Config Server Proxies. Particularly if you have a large environment. CS Proxy will reduce the load on the main config server. And if config server goes down, the clients connected to CS Proxies will still have read access to data so the impact to the environment as a whole is lessened.
Offline genesysguru
    • Genesys Guru Blog
« Reply #3 on: January 18, 2014, 09:58:59 AM »
In large deployments with IWS you definitely need multiple CSPs to share the load on the configuration layer.
