" /> StatServer 812 Java 7 - Genesys CTI User Forum
Author Topic: StatServer 812 Java 7  (Read 2457 times)
Offline PFCCWA
« on: January 24, 2014, 02:24:53 PM »
For anyone who has deployed StatServer 8.1.2, it now has support for java 1.7, however when I tried to use it with Java7u51, it wont work.
Does anyone know which version of java 7 is supported?
Cant find any updated document specifying the actual release.
thanks,
Re: StatServer 812 Java 7
« Reply #1 on: January 24, 2014, 03:23:56 PM »
Read Deployment guide...come on...
Offline PFCCWA
« Reply #2 on: January 24, 2014, 03:28:23 PM »
Deployment states 1.7 only without going into more detail than previous docs.
I assumed this means any java 7 version.
It works on 1.5.0.18, last one attempted.
« Reply #3 on: January 24, 2014, 03:48:13 PM »
You sure it is a 32bits or 64bits JDK and not JRE, right? According of course to your SS version used.
8.1.2 states clearly only JDK 1.7 not 1.4 nor 1.5 anymore, so if yours is working with 1.4 or 1.5 then probably your version is not 8.1.2.
If it still doesn't work after all this checked, then check your logs and analyze them.
