" /> Genesys Configuration Database Structure/Schema - Genesys CTI User Forum
Author Topic: Genesys Configuration Database Structure/Schema  (Read 4326 times)
Offline rkpatel78
    • Ranjit Patel
« on: February 21, 2014, 11:32:40 PM »
I am looking for "Genesys Configuration Database Structure/Schema" if any one can share that will be g8 help ?
Re: Genesys Configuration Database Structure/Schema
« Reply #1 on: February 24, 2014, 01:56:13 PM »
Why do you not create UML or export schema from SQL console for the RDBMS? Genesys in general does not provide schema structure for CFG layer.
Offline sunbabu15
« Reply #2 on: March 02, 2014, 01:20:25 AM »
Can someone please share the Genesys Configuration Database Structure/Schema doc for Genesys 8.1 .
Regards,
Sun
« Reply #3 on: March 03, 2014, 08:14:55 AM »
As it was written above - again for you:
Database schema for the Genesys configuration database is not available.Genesys "Configuration Import Wizard" document gives schema definition in XML or closest document is Configuration Platform SDK API Reference, which is available on Genesys documentation page.
