" /> ird email parent id - Genesys CTI User Forum
Author Topic: ird email parent id  (Read 3438 times)
Offline dtorres265
ird email parent id
« on: March 25, 2014, 12:50:21 AM »
I would like to know if it's possible to get via IRD the parent id or any other attribute of a response of an email previously handled,  the idea is to  tight the history of the thread of this email to our agent application.
thanks.
Re: ird email parent id
« Reply #1 on: March 25, 2014, 01:47:52 AM »
That is automatically done by URS/IXN/UCS. In that way agent can see on GAD/IWS the customer history and follow up the current communication
Offline Grand_Master
« Reply #2 on: March 25, 2014, 03:37:37 AM »
You can also do a UCS query if you want to return the interaction to the same agent that handled it previously.  Not quite sure exactly what your question is.
Offline dtorres265
« Reply #3 on: March 25, 2014, 07:01:48 PM »
could you please give me some examples on how to query from ird the UCS and compare for example the parent ID?
Offline Iphoneuser
« Reply #4 on: March 25, 2014, 07:21:57 PM »
i think you can use dbtool to query ucs db
Offline ledge
« Reply #5 on: April 08, 2014, 10:57:18 PM »
[quote author=dtorres265 link=topic=8268.msg36443#msg36443 date=1395774108]
The easiest way to query the UCS database directly is via a stored procedure. That way you don't have to bother with field, formats and table access objects.
You can call stored procedures via the Database Wizard object in IRD.
