" /> genesys service start error - Genesys CTI User Forum
Author Topic: genesys service start error  (Read 16142 times)
Eugene Khoo
has anyone encountered this error:
C:\GCTI\StatServer_PHP24F>statserv.exe service statserver_service host cme_php
port 2020 app "StatServer_CCP_PHP" l "7260@cme_php"
service_startup Changing working folder to C:\GCTI\StatServer_PHP24F\
Trying to start Service Control Dispatcher...FAILED
Cannot start Service Control Manager, error code = 1063
Trying to stop the service...DONE
DONE
Offline gustav
Re: genesys service start error
« Reply #1 on: June 01, 2010, 07:10:01 PM »
Ensure that you have the JAVA_HOME path set, and that it does not have a space ie. "Program Files\"  .  Also, use the startup.bat file in the gdesktop directory, as it will start it as a service (not the .exe).
Offline Steve
« Reply #2 on: June 02, 2010, 10:00:35 AM »
Don't you need minus signs to show the keys -
C:\GCTI\StatServer_PHP24F>statserv.exe -service statserver_service -host cme_php -port 2020 -app "StatServer_CCP_PHP" -l "7260@cme_php"
tony
« Reply #3 on: June 02, 2010, 10:38:46 AM »
...And I think there should there be a backslash (not an arrow to show the executable location...?
C:\GCTI\StatServer_PHP24F\statserv.exe
instead of:
Making it;
C:\GCTI\StatServer_PHP24F\statserv.exe -service statserver_service -host cme_php -port 2020 -app "StatServer_CCP_PHP" -l "7260@cme_php"
Offline gustav
« Reply #4 on: June 07, 2011, 05:37:39 PM »
This is usually a JAVA_HOME environment variable issue.  Verify both the environment variable and you Java directory to ensure they are in sync.
From the command prompt run> set
to see the variable settings or run> echo %JAVA_HOME%
to update without restarting run> set JAVA_HOME = <full path>
Offline gustav
« Reply #5 on: October 24, 2011, 02:21:56 PM »
Another thing to check here is the version of Java, I have had this issue when incompatible versions are being used.
Offline alexnikol
« Reply #6 on: October 25, 2011, 07:25:14 AM »
Which version of Java is incompatible can you please specify and post those versions which you have encountered problem with.
Marked as best answer by on Today at 06:05:37 PM
Offline gustav
« Reply #7 on: November 22, 2011, 07:20:06 PM »
  • Undo Best Answer
  • 1.6 for Genesys 7.6-8.1
    I have had issues with later version of 1.6, but have found earlier versions (ie _17) have been successful
    « Last Edit: December 15, 2011, 09:07:38 PM by gustav »
