" /> Cisco CUCM & Genesys: CAUSE_NETWORK_NOT_OBTAINABLE - Genesys CTI User Forum
Author Topic: Cisco CUCM & Genesys: CAUSE_NETWORK_NOT_OBTAINABLE  (Read 5466 times)
Offline Cuore_2003
« on: November 11, 2014, 12:12:18 PM »
Dear all.
For any reason, and sometimes, when an agent sets an incoming call in hold or if the agent tries to transfer the incoming calll (the call is on hold automatically before the transfer) we get the following error messages in TServer logs:
- ConnFailedEvent
- CAUSE_NETWORK_NOT_OBTAINABLE
- CAUSE_TEMPORARYFAILURE
The real problem is that you can not retrieve the call. The client is waiting (he's on hold!) until he decide hang up.
Here you can see a description of the error (where NNNNNNNNNN is the incoming call number):
@11:37:32.1066 [((1] 1 243 S 9 'CallEv(2)=> Type=ConnFailedEvent Cause=CAUSE_NETWORK_NOT_OBTAINABLE CiscoCause=CAUSE_TEMPORARYFAILURE Cid=17826421 CCurCldA=13016[P_Telefonos] CCurClgA=NNNNNNNNNN MetaCode(true)=META_CALL_PROGRESS Addr=13016[P_Telefonos] CiscoAddrType=1'
@11:37:32.1066 [((1] 1 316 S 9 'CallEv(2)=> Type=CallCtlConnFailedEv Cause=CAUSE_NETWORK_NOT_OBTAINABLE ECldA=76382[P_Telefonos] EClgA=NNNNNNNNNN
ELRdrA=76382[P_Telefonos] CiscoCause=CAUSE_TEMPORARYFAILURE Cid=17826421 CCurCldA=13016[P_Telefonos] CCurClgA=NNNNNNNNNN MetaCode(false)=META_CALL_PROGRESS Addr=13016[P_Telefonos] CiscoAddrType=1'
Cisco CUCM version: 8.6.2.22900-9
Genesys TServer version: 8.0.104.05
Do you have any idea about this behaviour?
Thanks in advanced for your help.
« Last Edit: November 11, 2014, 12:24:08 PM by Cuore_2003 »
Re: Cisco CUCM & Genesys: CAUSE_NETWORK_NOT_OBTAINABLE
« Reply #1 on: November 11, 2014, 12:48:10 PM »
Seems to be an issue on Cisco side, have you queried it with them? Check your release notes or try to apply last patch if possible
Offline kbreboot
« Reply #2 on: November 12, 2014, 06:16:32 AM »
did you upgraded CUCM recently? or is this an new deployment?
Offline Cuore_2003
« Reply #3 on: November 12, 2014, 07:44:40 AM »
[i]Cavagnaro: Seems to be an issue on Cisco side, have you queried it with them? Check your release notes or try to apply last patch if possible[/i]
Answer: Cisco support is working on the issue. I know they made the following tasks:
- New transcoding resource Cisco "Media Termination Point Hardware" MTP4403A70D39C0
- New "Media Termination Point" called einmm-orga_mtp. It's a kind of Cisco IOS Enhanced Software Media Termination Point.
- Both resources have been associated with the CallCenter group "Media Resource Group" MRG_MTP.
- And they are checking interconnection problems with NGN network.
The tasks made did not resolve the problem and, moreover, they had to remove the hardware and software resources because it caused problems with the codec execution (stream manager)
Cisco support is going to check the release notes and the possibility or upgrade Cisco software (checking before Genesys compatibility)
[i]kbreboot: did you upgraded CUCM recently? or is this an new deployment?[/i]
Answer: It's a new deployment.
Thanks in advanced.
« Reply #4 on: November 12, 2014, 12:00:40 PM »
Well, the root is on Cisco, Genesys is only reporting what cisco is informing so you will have to see what they do to solve  :-\
Offline n3xth0p
« Reply #5 on: November 12, 2014, 12:07:31 PM »
Hello Cuore_2003,
Here is information about Genesys and Cisco compatibility
Question Detail
What versions of Cisco Unified Communications Manager (CUCM) are supported by Genesys?
Answer
T-Server for Cisco UCM 8.1 is supported for deployments with the following versions of Cisco UCM: v4.1.x, v4.2.x, v5.1.x, v6.1.x, v7.0.x, v7.1.x, v.8.0.x, v.8.5.x, 8.6.x, 9.0, 9.1 and, starting with T-Server version  8.1.200.06 , CUCM version v.10.0.x
T-Server for Cisco UCM 8.1 was tested with these specific Cisco UCM point releases and JTAPI versions:
Version 4.1(3)sr1 with JTAPI 2.1(3.9)
Version 4.2(1) with JTAPI 2.2(1.21)
Version 5.1.3.1106-1 with JTAPI 3.1(3.8)
Version v6.1.1.2000-3 with JTAPI 6.0(1.1000)-5
Version 7.0.1.11000-2 with JTAPI 7.0(1.1000)
Version 7.1.2.20000-2 with JTAPI 7.1(2.10000)-3
Version 8.0.2.10000-24and JTAPI version 8.0(2.10000)
Version 8.5.1.10000-26 and JTAPI version 8.5(1.10000)-1
Version 8.6.1.20000-1 with JTAPI version 8.6(1.10000)-1
Version 9.0.10000-37 with JTAPI version 9.0(1.10000)-1
Version 9.1.1.20000-5 with JTAPI version 9.1(1.10000)-2
Version ES 10.0(1.12008-3) with JTAPI version 10.0(1.10000)-2
« Last Edit: November 12, 2014, 12:09:10 PM by n3xth0p »
Offline Cuore_2003
« Reply #6 on: November 20, 2014, 10:50:59 AM »
Dear all.
Many thanks for the answers.
Best regards.
