" /> Third Party IVR Driver Integration - Genesys CTI User Forum
Author Topic: Third Party IVR Driver Integration  (Read 2411 times)
Offline PFCCWA
« on: November 19, 2014, 05:00:52 PM »
We are looking to integrate Genesys with a third party ivr and wanted to verify that an ivr driver is not provided by Genesys, unless it is MPS or WVR?
In this case the third party will develop the driver and we will just need to create the ivr driver application in cme which contains driver working directory/command line/args (with third party template?) plus other required objects (ivr t-server/iserver/host/dns/vtps etc) so can be monitored.
I also noticed this third party is not listed in the ivr types however there is 'Other IVR Type' option so assume ill need to select this.
Integration would be Avaya-Genesys.
thanks.
Offline Fra
Re: Third Party IVR Driver Integration
« Reply #1 on: November 20, 2014, 09:59:01 AM »
Up to 8.0, Genesys used to provide the IVR driver for Conversant and Edify as well.
Fra
Offline genesysguru
    • Genesys Guru Blog
« Reply #2 on: November 20, 2014, 01:55:33 PM »
Recently worked on a project where we needed to develop a custom IVR driver for Voxeo. All works fine and it is not rocket science.
Regards
