" /> action codes in ccpulse - Genesys CTI User Forum
Author Topic: action codes in ccpulse  (Read 2821 times)
Offline S2H
« on: January 13, 2015, 01:14:16 PM »
  I tried to display the break time & lunch time in ccpulse. But it is not working.
I  have created two action codes,
  Break    Not Ready    1
  Lunch    Not Ready    2
And, i have created two filters,
PairExist("Break","1")
PairExist("Lunch","2")
The stat which which i have used is Total_Not_Ready_Time with the above filters,
MainMask    NotReadyForNextCall
Category    TotalAdjustedTime
Subject      AgentStatus
Objects      Agent, GroupAgents, GroupPlaces, Place
plz help me regarding this issue. Thanks in advance
Re: action codes in ccpulse
« Reply #1 on: January 13, 2015, 01:28:48 PM »
I think, the filter should be in configured with following format :
[quote]PairExist("ReasonCode", 1)
PairExist("ReasonCode", 2)[/quote]
« Reply #2 on: January 13, 2015, 01:28:48 PM »
Check your Tserver logs to see if they match your filters
