" /> "Zipped IP upload failed. Missing template files" when trying to upload Pulse - Genesys CTI User Forum
Author Topic: "Zipped IP upload failed. Missing template files" when trying to upload Pulse  (Read 2614 times)
Offline ryusuf
Please help me out if anyone has an idea on this. I am newbie to Genesys and its components. Appreciate any help.
When i try to upload Pulse 8.1.4 plugin IP from the GAX 8.1.4 i get the following message "Zipped IP upload failed. Missing template files". I have zipped the ip folder with the xml file in it.
Thank you
Best Regards
ryusuf
What version of confserv are you using? Use latest version of confserv and GA.
Note: The import of this template is not necessary and you can fill the option and section manually.
