" /> Composer Block Copy/Paste Bug - Genesys CTI User Forum
Author Topic: Composer Block Copy/Paste Bug  (Read 4119 times)
Offline DamoVoda
« on: March 26, 2015, 03:13:44 PM »
We have a dev machine that we recently updated with Composer 8.14 on Eclipse 4.2.2. We are currently experiencing an issue whereby we cannot copy and paste composer blocks.
Steps to reproduce:
Highlight block
Right Click
Copy
Right Click Paste
When this has been done a star appears by the file name to indicate a change has been made but no copy of the block exists in the flow and no new VXML is generated. We can copy and paste VXML just fine so this is quite peculiar. Has anyone come across this issue? Any workarounds available?
Re: Composer Block Copy/Paste Bug
« Reply #1 on: March 26, 2015, 03:53:13 PM »
What happened to me was that block was copied but far far away from where I selected to be...noted when copiled and an error raised.
Searched and found the block very at the bottom far from everyone
Offline DamoVoda
« Reply #2 on: March 26, 2015, 04:05:20 PM »
Yes this is common and happens on our other machines all the time. This isn't the issue. We have tested this multiple times and can confirm that the block is not pasted on the flow, as I stated previously no new VXML is generated either. We're all scratching our heads over this one  ???
« Reply #3 on: March 26, 2015, 04:54:29 PM »
Time to open an eSR with Genesys
Offline hynsey
« Reply #4 on: March 27, 2015, 09:56:23 AM »
Was hoping that wouldn't be the case :(
thanks all
Offline zafzef.mourad
« Reply #5 on: March 30, 2015, 07:56:47 PM »
Open ur callflow or ur workflow and after right click on the block u need to copy and choice : Edit and duplicate
That's gonna resolve ur problem :-)
Offline hynsey
« Reply #6 on: April 16, 2015, 02:39:30 PM »
Hi Zafzef,
That doesn't resolve problems if I want to copy blocks from one callflow to another unfortunately.
I ended up completely removing Composer and eclipse. Also noted I had 32 bit eclipse installed (I'm on a 64 bit machine).
So I got x64 eclipse, and reinstalled composer, and it's working now :)
Cheers!
Adam G
« Reply #7 on: April 16, 2015, 04:27:30 PM »
I was in the middle of writing this, so... anyway;
Try using the various different methods of copy/paste:
Select, CTRL/C, then CTRL/P
Select, File/Edit Menu - Copy, then File/Edit Menu - Paste
Select, Right-Click/Copy, then Right-Click/Paste
At least one of them should work!
Offline hynsey
« Reply #8 on: April 16, 2015, 04:35:21 PM »
Appreciate the reply Adam, but I'd already tried all of those methods.
« Reply #9 on: April 16, 2015, 09:25:19 PM »
[quote author=adamgill link=topic=8772.msg39186#msg39186 date=1429201650]
Actually Eclipse uses it own library for handling copy paste due memory handle
