" /> reason code data - Genesys CTI User Forum
Author Topic: reason code data  (Read 4080 times)
Offline S2H
reason code data
« on: April 07, 2015, 07:06:14 PM »
In ccpulse options and in custom statistic section, the reasoncodedata is set to userdata;software;hardware. And what this option returns?
Re: reason code data
« Reply #1 on: April 07, 2015, 08:56:15 PM »
What?
Adam G
« Reply #2 on: April 08, 2015, 08:28:13 AM »
reasoncodedata is a Key Value Pair statistics, which is user configurable in the StatServer Options.  The Options you've listed are the default Values for the Pair.
Offline S2H
« Reply #3 on: April 08, 2015, 10:16:06 AM »
Thanks for your valuable information. Can we configure this in CCpulse options? And, whether this option is used to get hardware and software reasons? Can you give some examples where this option is used...
« Reply #4 on: April 08, 2015, 10:25:25 AM »
Usually,HW are from physical phones. SW are from agent application for example. The process how to get them within CCPulse is still same (just the filter format should be different)
Adam G
« Reply #5 on: April 08, 2015, 10:32:52 AM »
The reasoncodedata Options for the relevant Key Value Pairs are configured through the StatServer Application, in CIM/CME/cfg.
The population of reasoncodedata into Attached Data for Interactions is a Function within the Routing components.
Offline S2H
« Reply #6 on: April 08, 2015, 03:54:03 PM »
Thanks for the valuable information. So, can i create a filter like this,
reasoncodedate=pairexists("userdata","software","hardware").
Please correct me, if i am wrong.
Adam G
« Reply #7 on: April 08, 2015, 04:22:05 PM »
Something like that.... but you have to add the reasoncode Key Value Pairs into your StatServer and also associate them within your Routing...
OK <deep breath...>
To populate (any) Key Value Pair you must first apply it, through either a Routing Strategy - or allow it to be attached, as data, from something like a Softphone or CTI Toolbar.  In the case of reasoncodedata, the intention is to provide the means to allocate a "Reason Code" for an Interaction.  There are some Values associated by default - but you can add your own Values, too - the same as any pre-defined Key Value Pair.
In most cases, a Reason Code will be applied [i]after [/i]the call or interaction is complete - usually during After Call Work (ACW).  This is achieved through the Agent selecting an appropriate Reason Code and applying it, through their Softphone, Desktop or CTI Toolbar, during a period of ACW.  Once applied, it will become attached to the Call UData, through the Agents (Softphone or CTI Toolbar), which is connected to a TServer.  The TServer associates the Reason Code Key Value Pair to the ConnID of the Interaction.
...THEN the StatServer can pick up the Reason Code Key Value Pair and you can use it, for Reporting purposes.
So, your Filter is quite accurate - but it will have nothing to report on, if you don't first update your Routing to allow it to associate the Key Value Pairs for reasoncodedata.
.... <breathes out...>
[url=http://docs.genesys.com/Documentation/RTME/latest/User/Filters]http://docs.genesys.com/Documentation/RTME/latest/User/Filters[/url]
« Last Edit: April 08, 2015, 04:37:33 PM by adamgill »
« Reply #8 on: April 08, 2015, 05:17:11 PM »
Seems I need to learn how to translate English to English... Still don't understand original post :P
Adam G
« Reply #9 on: April 08, 2015, 07:31:02 PM »
I did my best, cav.... lol
