" /> Cant connect to SES link after sip server upgrade from 7.6 to 8.1 - Genesys CTI User Forum
Author Topic: Cant connect to SES link after sip server upgrade from 7.6 to 8.1  (Read 7259 times)
Offline TheVagab0nd
I am having the same problem with sip server on UNIX.
Here is what I did:
Created an application template for sip server using CME (upgrade project from 7.6 to 8.1)
Installed server application
Configured the options and all that good stuff in CME
Here is the SIP Server log:
Build with Genesys SIP Library 8.1.100.43
Build with TServerCommonPart 8.1.010.56
High Availability feature: ON
ISCC feature support:      ON
Genesys Common Library SE: 8.1.300.26 C2
TServer Library (TLib): 8.1.200.05 HA
      gmessage library: 8.1.300.00
      gservice library: 8.1.300.06 MT
      gthread  library: 8.1.300.01
Config Server support:  CfgLib 8.1.300.06
LCA support:            LCALib 8.1.300.07
License support:        GLMLib 8.1.300.03 MT (FLEXLm 11.9)
Message Server support: LogLib 8.1.300.08 MT
Nonstop Operation:      NSOLib 8.1.300.01 try/catch
SNMP support:          MngmLib 8.1.300.01
11:17:28.334 Std 05060 Application started
11:17:28.334: SipServer::DNOptions
@11:17:28.3353 [ISCC] Location localLocation: available cast types (route direct-callid reroute direct-uui direct-ani direct-notoken dnis-pool direct-digits pullback route-uui direct-network-callid)
@11:17:28.3353 [ISCC] Location localLocation: default cast type route
@11:17:28.3353 (STUCK_CALL_PERIODIC_TIMER):changed 'notify-idle-tout'=0
@11:17:28.3353 (SCPT) cl=0, not=0, check=600000
@11:17:28.3353 changed 'cleanup-idle-tout'=0
@11:17:28.3353 (STUCK_CALL_PERIODIC_TIMER):changed 'periodic-check-tout'=600000
11:17:28.335 -- Fail Route Supervision : Config : HWM = 10.000000
11:17:28.335 -- Fail Route Supervision : Config : LWM = 1.000000
11:17:28.335: MakeCall SDP
v=0
11:17:28.335: ParseAddress: Cannot parse: as <host>:<port>
11:17:28.335: Cannot parse:(null) as <host>:<port> External registrar not set.
11:17:28.335: SetInternalRegistrarEnabled(1)
11:17:28.335: SetOverrideToOnDivert(0)
11:17:28.335: SetInternalRegistrarPersistent(1)
11:17:28.335: SetSIPTreatmentsContinuous(0)
11:17:28.335  -- kpl-loss-rate values changed [r/w]: [10,100]
@11:17:28.3358 [TCONF] Registering CfgSwitch tenant=101
@11:17:28.3358 [TCONF] Registering CfgDN tenant=101
@11:17:28.3358 [TCONF] Registering CfgApplication tenant=101
@11:17:28.3358 [TCONF] Registering CfgHost tenant=0
@11:17:28.3358 [TCONF] Registering CfgTenant tenant=0
@11:17:28.3359 [TCONF] Registering CfgPhysicalSwitch tenant=0
@11:17:28.3359 [TCONF] Registering CfgAgentLogin tenant=101
@11:17:28.3359 [TCONF] DN added (dbid 333) (number 7368) (switch-dbid 103)
@11:17:28.3360 [TCONF] DN added (dbid 334) (number 7367) (switch-dbid 103)
@11:17:28.3360 [TCONF] DN added (dbid 490) (number 7375) (switch-dbid 103)
@11:17:28.3361 [TCONF] DN added (dbid 515) (number 7378) (switch-dbid 103)
@11:17:28.3362 [TCONF] DN added (dbid 275) (number 8000) (switch-dbid 103)
@11:17:28.3363 [TCONF] DN added (dbid 276) (number 8001) (switch-dbid 103)
@11:17:28.3363 [TCONF] DN added (dbid 277) (number 8002) (switch-dbid 103)
@11:17:28.3364 [TCONF] DN added (dbid 278) (number 8003) (switch-dbid 103)
@11:17:28.3365 [TCONF] DN added (dbid 279) (number 8004) (switch-dbid 103)
@11:17:28.3366 [TCONF] DN added (dbid 280) (number 8005) (switch-dbid 103)
@11:17:28.3366 [TCONF] DN added (dbid 281) (number 8006) (switch-dbid 103)
@11:17:28.3367 [TCONF] DN added (dbid 282) (number 8007) (switch-dbid 103)
@11:17:28.3367 [TCONF] DN added (dbid 283) (number 8008) (switch-dbid 103)
@11:17:28.3368 [TCONF] DN added (dbid 284) (number 8009) (switch-dbid 103)
@11:17:28.3369 [TCONF] DN added (dbid 285) (number 8010) (switch-dbid 103)
@11:17:28.3369 [TCONF] DN added (dbid 286) (number 8011) (switch-dbid 103)
@11:17:28.3370 [TCONF] DN added (dbid 287) (number 8012) (switch-dbid 103)
@11:17:28.3371 [TCONF] DN added (dbid 288) (number 8013) (switch-dbid 103)
@11:17:28.3372 [TCONF] DN added (dbid 289) (number 8014) (switch-dbid 103)
@11:17:28.3372 [TCONF] DN added (dbid 290) (number 8015) (switch-dbid 103)
@11:17:28.3373 [TCONF] DN added (dbid 291) (number 8016) (switch-dbid 103)
@11:17:28.3374 [TCONF] DN added (dbid 292) (number 8017) (switch-dbid 103)
@11:17:28.3375 [TCONF] DN added (dbid 293) (number 8018) (switch-dbid 103)
@11:17:28.3376 [TCONF] DN added (dbid 294) (number 8019) (switch-dbid 103)
@11:17:28.3376 [TCONF] DN added (dbid 295) (number 8020) (switch-dbid 103)
@11:17:28.3377 [TCONF] DN added (dbid 296) (number 8021) (switch-dbid 103)
@11:17:28.3378 [TCONF] DN added (dbid 297) (number 8022) (switch-dbid 103)
@11:17:28.3378 [TCONF] DN added (dbid 298) (number 8023) (switch-dbid 103)
@11:17:28.3379 [TCONF] DN added (dbid 299) (number 8024) (switch-dbid 103)
@11:17:28.3380 [TCONF] DN added (dbid 300) (number 8025) (switch-dbid 103)
@11:17:28.3381 [TCONF] DN added (dbid 301) (number 8026) (switch-dbid 103)
@11:17:28.3381 [TCONF] DN added (dbid 302) (number 8027) (switch-dbid 103)
@11:17:28.3382 [TCONF] DN added (dbid 303) (number 8028) (switch-dbid 103)
@11:17:28.3383 [TCONF] DN added (dbid 304) (number 8029) (switch-dbid 103)
@11:17:28.3383 [TCONF] DN added (dbid 305) (number 8030) (switch-dbid 103)
@11:17:28.3384 [TCONF] DN added (dbid 306) (number 8031) (switch-dbid 103)
@11:17:28.3385 [TCONF] DN added (dbid 307) (number 8032) (switch-dbid 103)
@11:17:28.3386 [TCONF] DN added (dbid 308) (number 8033) (switch-dbid 103)
@11:17:28.3386 [TCONF] DN added (dbid 309) (number 8034) (switch-dbid 103)
@11:17:28.3387 [TCONF] DN added (dbid 310) (number 8035) (switch-dbid 103)
@11:17:28.3388 [TCONF] DN added (dbid 311) (number 8036) (switch-dbid 103)
@11:17:28.3389 [TCONF] DN added (dbid 312) (number 8037) (switch-dbid 103)
@11:17:28.3389 [TCONF] DN added (dbid 313) (number 8038) (switch-dbid 103)
@11:17:28.3390 [TCONF] DN added (dbid 314) (number 8039) (switch-dbid 103)
@11:17:28.3391 [TCONF] DN added (dbid 315) (number 8040) (switch-dbid 103)
@11:17:28.3391 [TCONF] DN added (dbid 316) (number 8041) (switch-dbid 103)
@11:17:28.3392 [TCONF] DN added (dbid 317) (number 8042) (switch-dbid 103)
@11:17:28.3393 [TCONF] DN added (dbid 318) (number 8043) (switch-dbid 103)
@11:17:28.3393 [TCONF] DN added (dbid 319) (number 8044) (switch-dbid 103)
@11:17:28.3394 [TCONF] DN added (dbid 320) (number 8045) (switch-dbid 103)
@11:17:28.3395 [TCONF] DN added (dbid 321) (number 8046) (switch-dbid 103)
@11:17:28.3396 [TCONF] DN added (dbid 322) (number 8047) (switch-dbid 103)
@11:17:28.3397 [TCONF] DN added (dbid 326) (number 7301) (switch-dbid 103)
@11:17:28.3397 [TCONF] DN added (dbid 327) (number 7302) (switch-dbid 103)
@11:17:28.3398 [TCONF] DN added (dbid 328) (number 7304) (switch-dbid 103)
@11:17:28.3399 [TCONF] DN added (dbid 330) (number 7371) (switch-dbid 103)
@11:17:28.3400 [TCONF] DN added (dbid 331) (number 7370) (switch-dbid 103)
@11:17:28.3401 [TCONF] DN added (dbid 332) (number 7369) (switch-dbid 103)
@11:17:28.3401 [TCONF] DN added (dbid 435) (number 7374) (switch-dbid 103)
@11:17:28.3402 [TCONF] DN added (dbid 433) (number 9081111111) (switch-dbid 103)
@11:17:28.3403 [TCONF] DN added (dbid 226) (number 7372) (switch-dbid 103)
@11:17:28.3404 [TCONF] DN added (dbid 153) (number AvayaTrunk) (switch-dbid 103)
@11:17:28.3404 [TCONF] DN added (dbid 471) (number 7305) (switch-dbid 103)
@11:17:28.3405 [TCONF] DN added (dbid 472) (number 7306) (switch-dbid 103)
@11:17:28.3406 [TCONF] DN added (dbid 473) (number 7307) (switch-dbid 103)
@11:17:28.3407 [TCONF] DN added (dbid 483) (number 2401111111) (switch-dbid 103)
@11:17:28.3408 [TCONF] DN added (dbid 484) (number 5711111111) (switch-dbid 103)
@11:17:28.3408 [TCONF] DN added (dbid 485) (number 5731111111) (switch-dbid 103)
@11:17:28.3409 [TCONF] DN added (dbid 486) (number 3081111111) (switch-dbid 103)
@11:17:28.3410 [TCONF] DN added (dbid 487) (number 7131111111) (switch-dbid 103)
@11:17:28.3410 [TCONF] DN added (dbid 488) (number 4701111111) (switch-dbid 103)
@11:17:28.3411 [TCONF] DN added (dbid 494) (number 7741111111) (switch-dbid 103)
@11:17:28.3412 [TCONF] DN added (dbid 495) (number 7791111111) (switch-dbid 103)
@11:17:28.3412 [TCONF] DN added (dbid 496) (number 2141111111) (switch-dbid 103)
@11:17:28.3413 [TCONF] DN added (dbid 497) (number 2091111111) (switch-dbid 103)
@11:17:28.3414 [TCONF] DN added (dbid 498) (number 5161111111) (switch-dbid 103)
@11:17:28.3415 [TCONF] DN added (dbid 221) (number 7373) (switch-dbid 103)
@11:17:28.3415 [TCONF] DN added (dbid 222) (number 7200) (switch-dbid 103)
@11:17:28.3416 [TCONF] DN added (dbid 225) (number 7300) (switch-dbid 103)
@11:17:28.3417 [TCONF] DN added (dbid 499) (number 8131111111) (switch-dbid 103)
@11:17:28.3418 [TCONF] DN added (dbid 500) (number 9891111111) (switch-dbid 103)
@11:17:28.3418 [TCONF] DN added (dbid 501) (number 2281111111) (switch-dbid 103)
@11:17:28.3419 [TCONF] DN added (dbid 502) (number 3231111111) (switch-dbid 103)
@11:17:28.3420 [TCONF] DN added (dbid 503) (number 7376) (switch-dbid 103)
@11:17:28.3420 [TCONF] DN added (dbid 504) (number 7377) (switch-dbid 103)
@11:17:28.3421 [TCONF] DN added (dbid 505) (number 7308) (switch-dbid 103)
@11:17:28.3422 [TCONF] DN added (dbid 506) (number 7309) (switch-dbid 103)
@11:17:28.3423 [TCONF] DN added (dbid 507) (number 7310) (switch-dbid 103)
@11:17:28.3424 [TCONF] DN added (dbid 508) (number 7311) (switch-dbid 103)
@11:17:28.3425 [TCONF] DN added (dbid 509) (number 7312) (switch-dbid 103)
@11:17:28.3426 [TCONF] DN added (dbid 510) (number 7313) (switch-dbid 103)
TServer list
  list  <+M>
    dn-scope = undefined <DM>
    management-port = 0 <+D>
    license list  <+M>
      num-of-licenses = 48 <+>
      num-sdn-licenses = 48 <+>
    tenant-profile list  <+>
      check-tenant-profile = false <+D>
      @tenant-name = 'Resources' <+>
      @tenant-password = NULL <+D>
    server-id = 144 <+DM>
    customer-id = NULL <+D>
    @location = 'SIP_Switch' <+>
    background-processing = false <+>
    background-timeout = '60 msec' <+D>
    req-distrib-event-support = no-check <DM>
    extrouter list  <+M>
      handle-vsp = all <+>
      reconnect-tout = '5 sec' <+D>
      request-tout = '20 sec' <+D>
      timeout = '1 min' <+>
      report-connid-changes = true <+>
      match-call-once = true <+D>
      compound-dn-representation = true <DM>
      use-data-from = main <+>
      tcs-use = never <+D>
      tcs-queue = NULL <+D>
      cluster-role = off <DM>
      cast-type = 'route direct-callid reroute direct-uui direct-ani direct-notoken dnis-pool direct-digits pullback route-uui direct-network-callid' <+D>
      register-tout = '2 sec' <+D>
      register-attempts = 5 <+D>
      default-dn = NULL <+D>
      route-dn = NULL <+D>
      dn-for-unexpected-calls = NULL <+D>
      use-implicit-access-numbers = false <+D>
      proxy-name = NULL <DM>
      pct-ci-req-tout = '500 msec' <DM>
      pct-rci-tout = '10 sec' <DM>
      direct-digits-key = 'CDT_Track_Num' <+D>
      cdt-udata-key -- alias for direct-digits-key
      network-request-timeout = '20 sec' <+D>
      resource-load-maximum = 0 <+D>
      resource-allocation-mode = circular <+D>
      cof-feature = true <+>
      cof-ci-req-tout = '500 msec' <+D>
      cof-rci-tout = '10 sec' <+D>
      cof-ci-wait-all = true <+>
      cof-ci-defer-delete = '0' <+D>
      cof-ci-defer-create = '0' <+D>
      default-network-call-id-matching = NULL <DM>
      event-propagation = list <+D>
      epp-tout = '0 sec' <DM>
      inbound-translator-%d array
      ipo-tout = '5 sec' <DM>
    backup-sync list  <+D>
      sync-reconnect-tout = '20 sec' <+D>
      protocol = 'default' <+D>
      addp-timeout = 0 <+D>
      addp-remote-timeout = 0 <+D>
      addp-trace = 'off' <+D>
    @server-name = 'sip_server_new' <+>
    propagated-call-type = false <DM>
    consult-user-data = separate <+D>
    user-data-limit = 16000 <+D>
    merged-user-data = main-only <+D>
    merge-consult-data -- alias for merged-user-data
    ani-distribution = inbound-calls-only <+D>
    call-cleanup list  <+D>
      notify-idle-tout = '0' <+D>
      cleanup-idle-tout = '0' <+D>
      periodic-check-tout = '10 min' <+D>
    agent-reservation list  <+M>
      request-collection-time = '100 msec' <+D>
      reservation-time = '10 sec' <+>
      reject-subsequent-request = true <+D>
      collect-lower-priority-requests = true <DM>
    agent-logout-reassoc = false <DM>
    unknown-xfer-merge-udata = false <+D>
    clid-withheld-name = 'PRIVATE' <+D>
    releasing-party-report = false <DM>
    agent-group = NULL <+D>
    acw-persistent-reasons = true <DM>
    link-control list  <+DM>
      restart-cleanup-limit = 0 <DM>
      restart-cleanup-dly = 0 <DM>
      quiet-cleanup = false <DM>
      quiet-startup = false <DM>
      ha-sync-dly-lnk-conn = false <DM>
      reg-delay = 10 <+D>
      reg-silent = true <+D>
      use-link-bandwidth = 'auto' <DM>
      link-alarm-high = 0 <DM>
      link-alarm-low = 0 <DM>
    agent-strict-id = false <+D>
    untimed-wrap-up-value = 1000 <+D>
    wrap-up-threshold = 0 <+D>
    inbound-bsns-calls = false <+D>
    outbound-bsns-calls = false <+D>
    internal-bsns-calls = false <+D>
    unknown-bsns-calls = false <+D>
    bsns-call-dev-types = 0xF = +acdq +rp +rpq +xrp <DM>
    timed-acw-in-idle = true <+D>
    timed-cwk-in-idle -- alias for timed-acw-in-idle
    acw-in-idle-force-ready = true <+D>
    cwk-in-idle-force-ready -- alias for acw-in-idle-force-ready
    inherit-bsns-type = false <+D>
    agent-only-private-calls = false <DM>
    backwds-compat-acw-behavior = false <+D>
    override-switch-acw = false <+D>
    call-monitor-acw = false <DM>
    extn-no-answer-timeout = 15 <+D>
    posn-no-answer-timeout = 15 <+D>
    agent-no-answer-timeout = 15 <+D>
    extn-no-answer-overflow = NULL <+D>
    posn-no-answer-overflow = NULL <+D>
    agent-no-answer-overflow = NULL <+D>
    agent-no-answer-action = none <+D>
    nas-private = false <+D>
    recall-no-answer-timeout = 15 <+D>
    nas-indication = none <+D>
    prd-dist-call-ans-time = 0 <+D>
    max-pred-req-delay = 3 <+D>
    accept-dn-type = 0x11F = +extension +position +acdqueue +routedn +trunk +routequeue <+D>
    default-dn-type = none <+D>
    dn-del-mode = 'never' <+D>
    route-failure-alarm-high-wm = '10' <DM>
    route-failure-alarm-low-wm = '1' <DM>
    route-failure-alarm-period = 0 <DM>
    emulate-login = on-RP <+D>
    emulated-login-state = ready <+D>
    wrap-up-time = '0' <+D>
    legal-guard-time = '0' <+D>
    sync-emu-agent = false <+D>
    agent-logout-on-unreg = false <DM>
    agent-emu-login-on-call = false <DM>
    logout-on-out-of-service = false <DM>
    sip-enable-tcp-keep-alive = false <DM>
    mwi-host = NULL <+D>
    mwi-domain = NULL <+D>
    sip-tls-cert = NULL <DM>
    sip-tls-cert-key = NULL <DM>
    sip-tls-trusted-ca = NULL <DM>
    sip-tls-crl = NULL <DM>
    sip-tls-cipher-list = NULL <DM>
    sip-tls-target-name-check = NULL <DM>
    make-call-alert-info = '' <+D>
    sip-alert-info = '' <DM>
    sip-alert-info-external = '' <DM>
    sip-alert-info-consult = '' <DM>
    default-music = 'music/on_hold' <+D>
    music-in-conference-file = '' <+D>
    parking-music = 'music/silence' <+D>
    music-on-pbxpark = 'music/on_hold' <DM>
    connect-nailedup-on-login = '' <DM>
    ring-tone = 'music/ring_back' <+D>
    busy-tone = 'music/busy_5sec' <+D>
    fast-busy-tone = 'music/atb_5sec' <+D>
    silence-tone = 'music/silence' <+D>
    collect-tone = 'music/collect' <+D>
    music-in-queue-file = NULL <+D>
    ims-default-orig-ioi = NULL <+D>
    ims-default-icid-suffix = NULL <+D>
    ims-default-icid-prefix = NULL <+D>
    ims-route = NULL <DM>
    ims-sip-domain = NULL <DM>
    ims-sip-params = NULL <DM>
    ims-puid-domain = NULL <DM>
    p-asserted-identity = NULL <DM>
    privacy = NULL <DM>
    ims-skip-ifc = NULL <DM>
    ims-3pcc-prefix = NULL <DM>
    sip-address-srv = NULL <DM>
    userdata-map-trans-prefix = NULL <+D>
    partition-id = 'SipServerDefaultPartition' <DM>
    dial-plan = NULL <DM>
    cos = NULL <DM>
    info-pass-through = '' <DM>
    subscription-event-allowed = NULL <DM>
    encoding-area = NULL <DM>
    sip-hold-rfc3264 = 'false' <+D>
    sip-error-conversion = NULL <DM>
    sip-pass-from-parameters = NULL <DM>
    audio-codecs = 'telephone-event,PCMU,PCMA,G723,G729,GSM' <+D>
    sip-address = '10.22.49.41' <+>
    internal-registrar-domains = NULL <+D>
    sip-block-headers = NULL <DM>
    enforce-external-domains = NULL <+D>
    external-registrar = NULL <+D>
    mwi-implicit-notify = NULL <DM>
    default-route-point = NULL <DM>
    sip-pass-refer-headers = NULL <DM>
    dr-peer-trunk = NULL <DM>
    dr-peer-location = NULL <DM>
    sip-fqdn-ip-version = '4' <DM>
    authenticate-requests = NULL <DM>
    sip-vip-script-down = NULL <DM>
    sip-vip-script-up = NULL <DM>
    sip-nic-address = NULL <DM>
    sip-server-info = NULL <DM>
    sip-user-agent = NULL <DM>
    sip-answer-mode = NULL <DM>
    geo-location = NULL <DM>
    voice-quality-collector-uri = NULL <DM>
    sip-filter-media = '' <DM>
    fmfm-trunk-group = NULL <DM>
    fmfm-prompt-file = NULL <DM>
    fmfm-confirmation-digit = '0' <DM>
    sip-wait-ack-timeout = '2' <DM>
    agent-reject-route-point = '' <DM>
    overflow-location-map = '' <DM>
    encoding = NULL <DM>
    sip-enable-gdns = true <DM>
    sip-enable-moh = false <+D>
    sip-enable-100rel = true <+D>
    ringing-on-route-point = true <+D>
    sip-add-local-contact-user = false <DM>
    divert-on-ringing = true <+D>
    sip-enable-sdp-application-filter = false <+D>
    sip-enable-sdp-codec-filter = false <+D>
    sip-treatment-dtmf-interruptable = false <DM>
    enable-ims = false <+D>
    ims-propagate-pcvector = false <DM>
    internal-registrar-enabled = true <+D>
    override-to-on-divert = false <+D>
    internal-registrar-persistent = true <+>
    mwi-extension-enable = false <+D>
    mwi-agent-enable = false <+D>
    mwi-group-enable = false <+D>
    enable-strict-location-match = 0x0 = -msml -true -softswitch -trunk -all <DM>
    mwi-notify-unregistered-dn = false <DM>
    find-trunk-by-location = false <+D>
    sip-3pcc-from-pass-through = false <DM>
    event-ringing-on-100trying = true <+>
    ims-use-term-legs-for-routing = false <DM>
    emergency-recording-cleanup-enabled = false <+D>
    use-display-name = false <+D>
    init-dnis-by-ruri = false <+D>
    sip-proxy-headers-enabled = true <+D>
    sip-dtmf-send-rtp = false <DM>
    sip-enable-call-info = false <+D>
    enable-unknown-gateway = false <DM>
    refer-enabled = true <DM>
    sip-preserve-contact = false <DM>
    msml-support = false <DM>
    msml-record-support = false <DM>
    resource-management-by-rm = true <DM>
    record-consult-calls = false <DM>
    keep-mute-after-conference = false <DM>
    sip-tls-mutual = false <DM>
    sip-timer-c-support = false <DM>
    reason-in-extension = true <DM>
    sip-491-passthrough = false <DM>
    sip-enable-100rel-predictivecall = false <DM>
    session-refresh-enforced = true <DM>
    mwi-port = 5060 <+D>
    session-refresh-interval = 1800 <+D>
    sip-port = 5060 <+D>
    sip-port-tls = 0 <DM>
    dtmf-payload = 127 <+>
    max-legs-per-sm = 0 <+D>
    server-role = 0 <DM>
    subscription-timeout = 180 <+D>
    subscription-delay = 0 <DM>
    registrar-default-timeout = 1800 <+>
    sip-invite-timeout = 0 <+D>
    sip-invite-treatment-timeout = 0 <+D>
    cpd-info-timeout = 3 <+D>
    timeguard-reduction = 0 <DM>
    sip-ring-tone-mode = 0 <DM>
    sip-replaces-mode = 0 <DM>
    sip-ip-tos = 256 <DM>
    sip-retry-timeout = 30 <DM>
    busy-tone-duration = 5 <DM>
    feature-code-park = 10 <DM>
    feature-code-retrieve = 11 <DM>
    feature-code-pickup = 12 <DM>
    max-parking-time = 0 <DM>
    sip-remote-del-from-conf = false <DM>
    sip-enable-call-info-extended = true <DM>
    sip-link-type = 0 <DM>
    overload-ctrl-threshold = 0 <DM>
    overload-ctrl-dialog-rate-capacity = 400 <DM>
    overload-ctrl-call-rate-capacity = 200 <DM>
    overload-ctrl-trequests-rate = 0 <DM>
    overload-ctrl-tc-trequests-rate = 1000 <DM>
    overload-ctrl-call-trequests-rate = 0 <DM>
    overload-ctrl-call-tupdateuserdata-requests-rate = 0 <DM>
    overload-ctrl-call-tapplytreatment-requests-rate = 0 <DM>
    overload-ctrl-tc-dn-register-capacity = 1000 <DM>
    overload-ctrl-tc-tclient-dnregister-capacity = 15000 <DM>
    overload-ctrl-tc-tclient-capacity = 15000 <DM>
    sip-max-retry-listen = 15 <DM>
    sip-pass-check = false <DM>
    enforce-trusted = true <DM>
    sip-from-pass-through = false <DM>
    mwi-mode = SUBSCRIBE <+D>
    Greetings: list  <DM>
      greeting-repeat-once-party = agent <DM>
      greeting-delay-events = none <DM>
      greeting-call-type-filter = 0x0 = -internal -outbound -consult <DM>
      greeting-notification = 0x0 = -started -complete <DM>
      greeting-after-merge = false <DM>
    send-200-on-clear-call = true <DM>
    sip-max-uui-length = 256 <DM>
    tlib-map-replace-dn = false <DM>
    blind-transfer-enabled = false <DM>
    sip-respect-privacy = true <DM>
    resolve-sip-address = false <DM>
    record-after-merge = false <DM>
    sip-add-contact-early-dialog = false <DM>
    dr-forward = off <DM>
    sip-enable-rfc3263 = false <DM>
    shutdown-sip-reject-code = 603 <DM>
    INVITE list
      extensions-%d array
      userdata-%d array
    UPDATE list
      extensions-%d array
      userdata-%d array
    INFO list
      extensions-%d array
      userdata-%d array
    REFER list
      extensions-%d array
      userdata-%d array
    BYE list
      userdata-%d array
    userdata-map-all-calls = false <DM>
    userdata-map-invite-after-refer = false <DM>
    sip-legacy-invite-retr-interval = false <DM>
    sip-referxfer-bye-timeout = 0 <DM>
    drop-nailedup-on-logout = false <DM>
    disconnect-nailedup-timeout = 0 <DM>
    cancel-monitor-on-unpark = true <DM>
    network-monitoring-timeout = 1 <DM>
    tlib-nic-monitoring = false <DM>
    sip-nic-monitoring = false <DM>
    sip-iptakeover-monitoring = false <DM>
    control-vip-scripts = false <DM>
    control-remote-vip-scripts = true <DM>
    vip-state-change-timeout = 10 <DM>
    call-observer-with-hold = false <DM>
    enable-busy-on-routed-calls = true <DM>
    operational-stat-timeout = 10 <DM>
    sip-outbound-proxy = false <DM>
    mwi-subscribe-vmb = false <DM>
    sip-referred-by-support = false <DM>
    sip-enable-aoc-after-established = false <DM>
    recording-failure-alarm-timeout = 0 <DM>
    msml-location-alarm-timeout = 0 <DM>
    sip-resubscribe-on-nonotify = false <DM>
    msml-record-metadata-support = false <DM>
    record-moh = true <DM>
    recording-client-stop-enable = true <DM>
    capacity-sip-error-code = 603 <DM>
    capacity-tlib-error-code = 0 <DM>
    fmfm-confirmation-timeout = 5 <DM>
    graceful-shutdown-sip-timeout = 4 <DM>
    disable-media-before-greeting = false <DM>
    observing-routing-point = NULL <+D>
    router-timeout = 10 <+D>
    after-routing-timeout = 10 <+D>
    set-notready-on-busy = NULL <DM>
    am-detected = drop <+D>
    fax-detected = drop <+D>
    silence-detected = drop <DM>
    cancel-monitor-on-disconnect = true <+D>
    logout-on-disconnect = true <+D>
    predictive-call-router-timeout = 20 <+>
    preview-expired = 90 <+D>
    intrusion-enabled = true <+D>
    monitor-internal-calls = true <+D>
    default-monitor-scope = call <+D>
    default-monitor-mode = mute <+D>
    monitor-consult-calls = false <DM>
    use-propagated-call-type = never <DM>
    sip-treatments-continuous = false <+D>
    map-sip-errors = true <DM>
    http-port = 0 <+D>
    SipErrorMap list
      sip-%d array
    stranded-calls-overflow = NULL <DM>
    stranded-on-arrival-calls-overflow = NULL <DM>
    stranded-call-redirection-limit = 4 <DM>
    forced-notready = true <+D>
    default-video-file = '' <+D>
    emergency-recording-filename = NULL <+D>
    restart-period = 20 <+D>
    reg-interval = 60 <+D>
    kpl-interval = 10 <+D>
    kpl-tolerance = 3 <+D>
    kpl-loss-rate = '10,100' <+D>
    call-rq-gap = 0 <+D>
    call-max-outstanding = 0 <+D>
    device-rq-gap = 0 <DM>
    rq-conflict-check = true <DM>
    backup-mode = none <+D>
    correct-rqid = false <+D>
    convert-otherdn = 0x7 = +agentid +reserveddn +fwd <DM>
    auto-logout-timeout = 0 <DM>
    auto-logout-ready = false <DM>
    call-type-rules list
      rule-%d array
    log-trace-flags = 0x6C00000 = +iscc +cfg$dn -cfgserv +passwd +udata -devlink -sw -req -callops -conn -client <+D>
  physical-switch array
    SIP_Switch [103] cfgtype = 72
  locally-scoped-dn array
  backup-server-%d array
  remote-server-%d array
  AgentLogin array
  DN array
    AvayaTrunk [153] dn = 'AvayaTrunk' type = TRUNK xtype = Trunk cfgtype = 14 sstype = 1 register-flag = true
    7373 [221] dn = '7373' type = RtQueue xtype = RouteDN cfgtype = 4 sstype = 1 register-flag = true
    7200 [222] dn = '7200' type = Extension xtype = DN cfgtype = 1 sstype = 1 reg-mode = 0x21 = +force register-flag = true
    7372 [226] dn = '7372' type = RtQueue xtype = RouteDN cfgtype = 4 sstype = 1 register-flag = true epn = 'daytime'
    8000 [275] dn = '8000' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8001 [276] dn = '8001' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8002 [277] dn = '8002' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8003 [278] dn = '8003' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8004 [279] dn = '8004' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8005 [280] dn = '8005' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8006 [281] dn = '8006' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8007 [282] dn = '8007' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8008 [283] dn = '8008' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8009 [284] dn = '8009' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8010 [285] dn = '8010' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8011 [286] dn = '8011' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8012 [287] dn = '8012' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8013 [288] dn = '8013' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8014 [289] dn = '8014' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8015 [290] dn = '8015' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8016 [291] dn = '8016' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8017 [292] dn = '8017' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8018 [293] dn = '8018' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8019 [294] dn = '8019' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8020 [295] dn = '8020' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8021 [296] dn = '8021' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8022 [297] dn = '8022' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8023 [298] dn = '8023' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8024 [299] dn = '8024' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8025 [300] dn = '8025' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8026 [301] dn = '8026' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8027 [302] dn = '8027' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8028 [303] dn = '8028' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8029 [304] dn = '8029' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8030 [305] dn = '8030' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8031 [306] dn = '8031' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8032 [307] dn = '8032' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8033 [308] dn = '8033' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8034 [309] dn = '8034' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8035 [310] dn = '8035' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8036 [311] dn = '8036' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8037 [312] dn = '8037' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8038 [313] dn = '8038' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8039 [314] dn = '8039' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8040 [315] dn = '8040' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8041 [316] dn = '8041' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8042 [317] dn = '8042' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8043 [318] dn = '8043' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8044 [319] dn = '8044' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8045 [320] dn = '8045' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8046 [321] dn = '8046' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    8047 [322] dn = '8047' type = Extension xtype = DN cfgtype = 7 sstype = 1 register-flag = true
    7371 [330] dn = '7371' type = RtQueue xtype = RouteDN cfgtype = 4 sstype = 1 register-flag = true
    7370 [331] dn = '7370' type = RtQueue xtype = RouteDN cfgtype = 4 sstype = 1 register-flag = true
    7369 [332] dn = '7369' type = RtQueue xtype = RouteDN cfgtype = 4 sstype = 1 register-flag = true
    7368 [333] dn = '7368' type = RtQueue xtype = RouteDN cfgtype = 4 sstype = 1 register-flag = true
    7367 [334] dn = '7367' type = RtQueue xtype = RouteDN cfgtype = 4 sstype = 1 register-flag = true
    9081111111 [433] dn = '9081111111' type = Extension xtype = DN cfgtype = 1 sstype = 1 reg-mode = 0x21 = +force register-flag = true
    7374 [435] dn = '7374' type = RtQueue xtype = RouteDN cfgtype = 4 sstype = 1 register-flag = true epn = 'nighttime'
    2401111111 [483] dn = '2401111111' type = Extension xtype = DN cfgtype = 1 sstype = 1 reg-mode = 0x21 = +force register-flag = true
    5711111111 [484] dn = '5711111111' type = Extension xtype = DN cfgtype = 1 sstype = 1 reg-mode = 0x21 = +force register-flag = true
    5731111111 [485] dn = '5731111111' type = Extension xtype = DN cfgtype = 1 sstype = 1 reg-mode = 0x21 = +force register-flag = true
    3081111111 [486] dn = '3081111111' type = Extension xtype = DN cfgtype = 1 sstype = 1 reg-mode = 0x21 = +force register-flag = true
    7131111111 [487] dn = '7131111111' type = Extension xtype = DN cfgtype = 1 sstype = 1 reg-mode = 0x21 = +force register-flag = true
    4701111111 [488] dn = '4701111111' type = Extension xtype = DN cfgtype = 1 sstype = 1 reg-mode = 0x21 = +force register-flag = true
    7375 [490] dn = '7375' type = RtQueue xtype = RouteDN cfgtype = 4 sstype = 1 register-flag = true
    7741111111 [494] dn = '7741111111' type = Extension xtype = DN cfgtype = 1 sstype = 1 reg-mode = 0x21 = +force register-flag = true
    7791111111 [495] dn = '7791111111' type = Extension xtype = DN cfgtype = 1 sstype = 1 reg-mode = 0x21 = +force register-flag = true
    2141111111 [496] dn = '2141111111' type = Extension xtype = DN cfgtype = 1 sstype = 1 reg-mode = 0x21 = +force register-flag = true
    2091111111 [497] dn = '2091111111' type = Extension xtype = DN cfgtype = 1 sstype = 1 reg-mode = 0x21 = +force register-flag = true
    5161111111 [498] dn = '5161111111' type = Extension xtype = DN cfgtype = 1 sstype = 1 reg-mode = 0x21 = +force register-flag = true
    8131111111 [499] dn = '8131111111' type = Extension xtype = DN cfgtype = 1 sstype = 1 reg-mode = 0x21 = +force register-flag = true
    9891111111 [500] dn = '9891111111' type = Extension xtype = DN cfgtype = 1 sstype = 1 reg-mode = 0x21 = +force register-flag = true
    2281111111 [501] dn = '2281111111' type = Extension xtype = DN cfgtype = 1 sstype = 1 reg-mode = 0x21 = +force register-flag = true
    3231111111 [502] dn = '3231111111' type = Extension xtype = DN cfgtype = 1 sstype = 1 reg-mode = 0x21 = +force register-flag = true
    7376 [503] dn = '7376' type = RtQueue xtype = RouteDN cfgtype = 4 sstype = 1 register-flag = true epn = 'daytime2'
    7377 [504] dn = '7377' type = RtQueue xtype = RouteDN cfgtype = 4 sstype = 1 register-flag = true epn = 'nighttime2'
    7378 [515] dn = '7378' type = RtQueue xtype = RouteDN cfgtype = 4 sstype = 1 reg-mode = 0x9 = +force +disabled register-flag = true epn = 'daytime2'
  DN/EXR array
    7300 [225] *cdn = '7300' type = RtQueue xtype = RouteDN cfgtype = 19 sstype = 1 auxdata = '7300'
      access-list array
      linked-resources array register-flag = true epn = 'daytime'
    7301 [326] *cdn = '7301' type = RtQueue xtype = RouteDN cfgtype = 19 sstype = 1 auxdata = '7301'
      access-list array
    7302 [327] *cdn = '7302' type = RtQueue xtype = RouteDN cfgtype = 19 sstype = 1 auxdata = '7302'
      access-list array
    7304 [328] *cdn = '7304' type = RtQueue xtype = RouteDN cfgtype = 19 sstype = 1 auxdata = '7304'
      access-list array
    7305 [471] *cdn = '7305' type = RtQueue xtype = RouteDN cfgtype = 19 sstype = 1 auxdata = '7305'
      access-list array
      linked-resources array register-flag = true epn = 'nighttime'
    7306 [472] *cdn = '7306' type = RtQueue xtype = RouteDN cfgtype = 19 sstype = 1 auxdata = '7306'
      access-list array
    7307 [473] *cdn = '7307' type = RtQueue xtype = RouteDN cfgtype = 19 sstype = 1 auxdata = '7307'
      access-list array
    7308 [505] *cdn = '7308' type = RtQueue xtype = RouteDN cfgtype = 19 sstype = 1 auxdata = '7308'
      access-list array
      linked-resources array register-flag = true epn = 'daytime2'
    7309 [506] *cdn = '7309' type = RtQueue xtype = RouteDN cfgtype = 19 sstype = 1 auxdata = '7309'
      access-list array
    7310 [507] *cdn = '7310' type = RtQueue xtype = RouteDN cfgtype = 19 sstype = 1 auxdata = '7310'
      access-list array
    7311 [508] *cdn = '7311' type = RtQueue xtype = RouteDN cfgtype = 19 sstype = 1 auxdata = '7311'
      access-list array
      linked-resources array register-flag = true epn = 'nighttime2'
    7312 [509] *cdn = '7312' type = RtQueue xtype = RouteDN cfgtype = 19 sstype = 1 auxdata = '7312'
      access-list array
    7313 [510] *cdn = '7313' type = RtQueue xtype = RouteDN cfgtype = 19 sstype = 1 auxdata = '7313'
      access-list array
    [-1] cdn = 'direct' type = N/A reg-mode = 0x0 =
      access-list array
WARNING: the following options were not used:
  key TServer [list] value: (size=311)
    key compatibility-port [String] value: "0"
    key ha-sync-dly-lnk-conn [String] value: "false"
    key quiet-cleanup [String] value: "false"
    key quiet-startup [String] value: "false"
    key restart-cleanup-dly [String] value: "0"
    key restart-cleanup-limit [String] value: "0"
    key rq-expire-tmout [String] value: "0"
    key rq-expire-tout [String] value: "0"
    key sip-enable-sdp-encryption-removal [String] value: "false"
    key sip-enforce-sdp-origin-rules [String] value: "false"
    key sip-refer-to-sst-enabled [String] value: "true"
@11:17:28.3449 [TCONF] Connecting to LCA at port 4999...
Open LCALayer on port=4999
LCA Library version 8.1.300.07
GLM_CO(tserver_sdn:switch_103,48,1)=0 count=48
11:17:28.357 Std 07101 Feature 'tserver_sdn': 48 licenses checked out
LICENSE: seat=48
GLM_CO(tserver_iscc:switch_103,1,1)=0 count=1
11:17:28.359 Std 07101 Feature 'tserver_iscc': 1 licenses checked out
11:17:28.359 {listener-set.3d3b000 {initialize}}
11:17:28.359 {listener-set.3d3b000 {on-port-created {port-id default}}}
11:17:28.359 {listener.4314bc0 {created} {port-id default}}
11:17:28.359 {listener.4314bc0 {open}}
@11:17:28.3599 [TSCP] Debug: Port parameters: ("protocol"="addp","addp-timeout"="0","addp-remote-timeout"="0","addp-trace"="off","name"="sip_server_new","server-type"="1","backlog"="5","port"="3000","id"="default","name"="TLib:8.1.200.05 HA
SIP Server, Version: 8.1.101.62 Compiled: Mar 20 2015 07:41:33
Genesys Telecommunications Laboratories, Inc., Copyright 1991 - 2008
11:17:28.359 Std 04525 Port 3000 opened for listening
11:17:28.359 {listener.4314bc0 {open complete} {socket 10}}
11:17:28.360 {listener-set.3d3b000 {on-port-created complete}}
11:17:28.360 {listener-set.3d3b000 {initialize complete}}
11:17:28.360 FrameworkUK version: N/A
11:17:28.360 +++ device_configure +++
  +++ Creating devices +++
    -- forced disable
  --- Creating devices ---
11:17:28.363 --- device_configure ---
@11:17:28.3639 [ISCC] LOG_COMPONENT is configured
@11:17:28.3639 [ISCC] ISCC configuration started
@11:17:28.3639 [ISCC] PROTOCOL_CONVERTER is configured
@11:17:28.3639 [ISCC] {server localServer {role primary} {role changed}}
@11:17:28.3639 [ISCC] Broadcast to all connected servers: message ISCCEventServerRoleChanged
ISCCAttributeServerRole Primary
@11:17:28.3640 [ISCC] configured as non-cluster location
@11:17:28.3640 [ISCC] Server node location sip_server_new@SIP_Switch added
@11:17:28.3640 [ISCC] CALL_MONITOR_COMPONENT is configured
@11:17:28.3641 [ISCC] DESTINATION_TRANSACTION_SET is configured
@11:17:28.3641 [ISCC] ORIGINATION_TRANSACTION_SET is configured
@11:17:28.3641 [ISCC] ORIGINATION_TRANSACTION_SET is enabled
@11:17:28.3641 [ISCC] RESOURCE_MANAGER is configured
@11:17:28.3641 [ISCC] ROUTE_DESTINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] CLUSTER_PROXY_ROUTE_DESTINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] CLUSTER_NODE_ROUTE_DESTINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] DIRECT_DESTINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] DNIS_POOL_DESTINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] REROUTE_DESTINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] CLUSTER_NODE_REROUTE_DESTINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] CLUSTER_PROXY_REROUTE_DESTINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] PULLBACK_DESTINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] CLUSTER_NODE_PULLBACK_DESTINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] CLUSTER_PROXY_PULLBACK_DESTINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] DEFAULT_DESTINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] TransferDataServer is configured
@11:17:28.3641 [ISCC] CLUSTER_NODE_REROUTE_ORIGINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] CLUSTER_PROXY_REROUTE_ORIGINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] REROUTE_ORIGINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] CLUSTER_NODE_PULLBACK_ORIGINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] CLUSTER_PROXY_PULLBACK_ORIGINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] PULLBACK_ORIGINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] CLUSTER_NODE_ROUTE_ORIGINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] CLUSTER_PROXY_ROUTE_ORIGINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] ROUTE_ORIGINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] DIRECT_ORIGINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] CLUSTER_NODE_DNIS_POOL_ORIGINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] CLUSTER_PROXY_DNIS_POOL_ORIGINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] DNIS_POOL_ORIGINATION_STRATEGY is configured
@11:17:28.3641 [ISCC] TransferDataClient is configured
@11:17:28.3641 [ISCC] DTC is configured
@11:17:28.3641 [ISCC] NETWORK_TRANSACTION_COMPONENT is configured
@11:17:28.3641 [ISCC] Resource (xrp) 7300 created
@11:17:28.3641 [ISCC] Resource 7300: created
@11:17:28.3641 [ISCC] Resource 7300: enabled
@11:17:28.3641 [ISCC] Resource (xrp) 7301 created
@11:17:28.3641 [ISCC] Resource 7301: created
@11:17:28.3641 [ISCC] Resource 7301: enabled
@11:17:28.3641 [ISCC] Resource (xrp) 7302 created
@11:17:28.3641 [ISCC] Resource 7302: created
@11:17:28.3641 [ISCC] Resource 7302: enabled
@11:17:28.3641 [ISCC] Resource (xrp) 7304 created
@11:17:28.3641 [ISCC] Resource 7304: created
@11:17:28.3641 [ISCC] Resource 7304: enabled
@11:17:28.3641 [ISCC] Resource (xrp) 7305 created
@11:17:28.3641 [ISCC] Resource 7305: created
@11:17:28.3641 [ISCC] Resource 7305: enabled
@11:17:28.3641 [ISCC] Resource (xrp) 7306 created
@11:17:28.3641 [ISCC] Resource 7306: created
@11:17:28.3641 [ISCC] Resource 7306: enabled
@11:17:28.3642 [ISCC] Resource (xrp) 7307 created
@11:17:28.3642 [ISCC] Resource 7307: created
@11:17:28.3642 [ISCC] Resource 7307: enabled
@11:17:28.3642 [ISCC] Resource (xrp) 7308 created
@11:17:28.3642 [ISCC] Resource 7308: created
@11:17:28.3642 [ISCC] Resource 7308: enabled
@11:17:28.3642 [ISCC] Resource (xrp) 7309 created
@11:17:28.3642 [ISCC] Resource 7309: created
@11:17:28.3642 [ISCC] Resource 7309: enabled
@11:17:28.3642 [ISCC] Resource (xrp) 7310 created
@11:17:28.3642 [ISCC] Resource 7310: created
@11:17:28.3642 [ISCC] Resource 7310: enabled
@11:17:28.3642 [ISCC] Resource (xrp) 7311 created
@11:17:28.3642 [ISCC] Resource 7311: created
@11:17:28.3642 [ISCC] Resource 7311: enabled
@11:17:28.3642 [ISCC] Resource (xrp) 7312 created
@11:17:28.3642 [ISCC] Resource 7312: created
@11:17:28.3642 [ISCC] Resource 7312: enabled
@11:17:28.3642 [ISCC] Resource (xrp) 7313 created
@11:17:28.3642 [ISCC] Resource 7313: created
@11:17:28.3642 [ISCC] Resource 7313: enabled
@11:17:28.3642 [ISCC] Resource (xrp) direct created
@11:17:28.3642 [ISCC] RESOURCE_SETS_MANAGER is configured
@11:17:28.3642 [ISCC] RESOURCE_SETS_MANAGER is enabled
@11:17:28.3642 [ISCC] COF is configured
@11:17:28.3642 [ISCC] EPC is configured
@11:17:28.3642 [ISCC] QUERY_MONITOR_PROCESSOR is configured
@11:17:28.3642 [ISCC] NUMBER_TRANSLATOR is configured
@11:17:28.3642 [ISCC] QMP is configured
@11:17:28.3642 [ISCC] TERMINATED_CALL_SET is configured
@11:17:28.3642 [ISCC] PATH_OPTIMIZATION_COMPONENT is configured
@11:17:28.3642 [ISCC] CLUSTER_SERVER_SET is configured
@11:17:28.3642 [ISCC] TEST_MANAGER_COMPONENT is configured
@11:17:28.3642 [ISCC] ISCC configuration finished
@11:17:28.3642 [ISCC] LOG_COMPONENT is enabled
@11:17:28.3642 [ISCC] ISCC enable started
@11:17:28.3642 [ISCC] PROTOCOL_CONVERTER is enabled
@11:17:28.3642 [ISCC] CALL_MONITOR_COMPONENT is enabled
@11:17:28.3642 [ISCC] DESTINATION_TRANSACTION_SET is enabled
@11:17:28.3642 [ISCC] RESOURCE_MANAGER is enabled
@11:17:28.3642 [ISCC] ROUTE_DESTINATION_STRATEGY is enabled
@11:17:28.3642 [ISCC] DIRECT_DESTINATION_STRATEGY is enabled
@11:17:28.3642 [ISCC] DNIS_POOL_DESTINATION_STRATEGY is enabled
@11:17:28.3642 [ISCC] REROUTE_DESTINATION_STRATEGY is enabled
@11:17:28.3642 [ISCC] PULLBACK_DESTINATION_STRATEGY is enabled
@11:17:28.3642 [ISCC] DEFAULT_DESTINATION_STRATEGY is enabled
@11:17:28.3642 [ISCC] TransferDataServer is enabled
@11:17:28.3643 [ISCC] REROUTE_ORIGINATION_STRATEGY is enabled
@11:17:28.3643 [ISCC] PULLBACK_ORIGINATION_STRATEGY is enabled
@11:17:28.3643 [ISCC] ROUTE_ORIGINATION_STRATEGY is enabled
@11:17:28.3643 [ISCC] DIRECT_ORIGINATION_STRATEGY is enabled
@11:17:28.3643 [ISCC] DNIS_POOL_ORIGINATION_STRATEGY is enabled
@11:17:28.3643 [ISCC] TransferDataClient is enabled
@11:17:28.3643 [ISCC] DTC is enabled
@11:17:28.3643 [ISCC] NETWORK_TRANSACTION_COMPONENT is enabled
@11:17:28.3643 [ISCC] COF is enabled
@11:17:28.3643 [ISCC] EPC is enabled
@11:17:28.3643 [ISCC] QUERY_MONITOR_PROCESSOR is enabled
@11:17:28.3643 [ISCC] NUMBER_TRANSLATOR is enabled
@11:17:28.3643 [ISCC] QMP is enabled
@11:17:28.3643 [ISCC] TERMINATED_CALL_SET is enabled
@11:17:28.3643 [ISCC] PATH_OPTIMIZATION_COMPONENT is enabled
@11:17:28.3643 [ISCC] ISCC enable finished
11:17:28.364 +++ device_open +++
11:17:28.364: SIPTSIFace::Open
11:17:28.364: SIPTSIFace::Init
@11:17:28.3643 [ISCC] SD message handler is set
common: option rebind-delay is set to the value '0'
11:17:28.364: CGSIPListener[0]:VIA("SIP/2.0/TCP 10.22.49.41:5060")
11:17:28.364: CGSIPListener[0]:CONTACT("<sip:10.22.49.41:5060;transport=tcp>")
11:17:28.364: CGSIPListener[0]:VIA("SIP/2.0/UDP 10.22.49.41:5060")
11:17:28.364: CGSIPListener[0]:CONTACT("<sip:10.22.49.41:5060>")
11:17:28.364: CGSIPListener[0]:VIA("SIP/2.0/TLS 10.22.49.41:0")
11:17:28.364: CGSIPListener[0]:CONTACT("<sip:10.22.49.41:0;transport=tls>")
11:17:28.364: Initialize transport layer
11:17:28.365: Tracking thread w/handle 1492731648
common: ConnTimerQueue option 'conn-timers-warning-processing-timeout' is set to the value '300' milliseconds
common: ConnTimerQueue option 'conn-timers-maximum-processing-timeout' is set to the value '1000' milliseconds
common: ConnTimerQueue option 'conn-timers-break-processing-loop' is set to the value 'false'
common: ConnTimerQueue option 'conn-timers-enable-extended-processing' is set to the value 'false'
11:17:28.371: Transport layer thread started
11:17:28.371: Transport layer initialized
11:17:28.415: SIP Transaction Manager ...
11:17:28.415: SIP Message Factory ...
11:17:28.415: SIPStack: RetryListen
11:17:28.415: Start SIP Listener TCP ...
11:17:28.415: Connect to the transport layer
11:17:28.415: Start SIP Listener UDP ...
11:17:28.416: Connection to the transport layer initialized
11:17:28.423: SIPCM: id=1
11:17:28.424: SIPPM: id=0
11:17:28.426: CUserPublicationManager: constructor
11:17:28.426: OVRLDControlManager: created
11:17:28.430: SIPCFG: Subscribe for user objects
11:17:28.430: SIPCFG: Subscription for ObjectType[15] objects RAW...In Progress
[153] dn = 'AvayaTrunk' type = Trunk xtype = DN cfgtype = 14 hash = 1 contact = 'sip:AvayaTrunk@10.20.10.146:5060;transport=udp' refer-enabled = false oosp-transfer-enabled = true
[221] dn = '7373' type = RoutingPoint xtype = DN cfgtype = 4 hash = 1
[222] dn = '7200' type = Extension xtype = DN cfgtype = 1 hash = 1
[226] dn = '7372' type = RoutingPoint xtype = DN cfgtype = 4 hash = 1
[275] dn = '8000' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[276] dn = '8001' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[277] dn = '8002' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[278] dn = '8003' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[279] dn = '8004' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[280] dn = '8005' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[281] dn = '8006' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[282] dn = '8007' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[283] dn = '8008' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[284] dn = '8009' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[285] dn = '8010' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[286] dn = '8011' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[287] dn = '8012' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
Offline TheVagab0nd
Re: Cant connect to SES link after sip server upgrade from 7.6 to 8.1
« Reply #1 on: April 09, 2015, 03:55:49 PM »
  DN/EXR array
      access-list array
      access-list array
      access-list array
      access-list array
      access-list array
      access-list array
      access-list array
      access-list array
      access-list array
      access-list array
      access-list array
      access-list array
      access-list array
      access-list array
LICENSE: seat=48
    -- forced disable
[288] dn = '8013' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[289] dn = '8014' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[290] dn = '8015' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[291] dn = '8016' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[292] dn = '8017' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[293] dn = '8018' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[294] dn = '8019' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[295] dn = '8020' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[296] dn = '8021' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[297] dn = '8022' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[298] dn = '8023' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[299] dn = '8024' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[300] dn = '8025' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[301] dn = '8026' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[302] dn = '8027' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[303] dn = '8028' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[304] dn = '8029' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[305] dn = '8030' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[306] dn = '8031' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[307] dn = '8032' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[308] dn = '8033' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[309] dn = '8034' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[310] dn = '8035' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[311] dn = '8036' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[312] dn = '8037' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[313] dn = '8038' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[314] dn = '8039' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[315] dn = '8040' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[316] dn = '8041' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[317] dn = '8042' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[318] dn = '8043' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[319] dn = '8044' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[320] dn = '8045' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[321] dn = '8046' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[322] dn = '8047' type = EAPort xtype = DN cfgtype = 7 hash = 1 contact = 'sip:10.20.221.49:5060' subscription-id = 'GVP' event-ringing-on-100trying = true
[330] dn = '7371' type = RoutingPoint xtype = DN cfgtype = 4 hash = 1
[331] dn = '7370' type = RoutingPoint xtype = DN cfgtype = 4 hash = 1
[332] dn = '7369' type = RoutingPoint xtype = DN cfgtype = 4 hash = 1
[333] dn = '7368' type = RoutingPoint xtype = DN cfgtype = 4 hash = 1
[334] dn = '7367' type = RoutingPoint xtype = DN cfgtype = 4 hash = 1
[433] dn = '9081111111' type = Extension xtype = DN cfgtype = 1 hash = 1
[435] dn = '7374' type = RoutingPoint xtype = DN cfgtype = 4 hash = 1
[483] dn = '2401111111' type = Extension xtype = DN cfgtype = 1 hash = 1
[484] dn = '5711111111' type = Extension xtype = DN cfgtype = 1 hash = 1
[485] dn = '5731111111' type = Extension xtype = DN cfgtype = 1 hash = 1
[486] dn = '3081111111' type = Extension xtype = DN cfgtype = 1 hash = 1
[487] dn = '7131111111' type = Extension xtype = DN cfgtype = 1 hash = 1
[488] dn = '4701111111' type = Extension xtype = DN cfgtype = 1 hash = 1
[490] dn = '7375' type = RoutingPoint xtype = DN cfgtype = 4 hash = 1
[494] dn = '7741111111' type = Extension xtype = DN cfgtype = 1 hash = 1
[495] dn = '7791111111' type = Extension xtype = DN cfgtype = 1 hash = 1
[496] dn = '2141111111' type = Extension xtype = DN cfgtype = 1 hash = 1
[497] dn = '2091111111' type = Extension xtype = DN cfgtype = 1 hash = 1
[498] dn = '5161111111' type = Extension xtype = DN cfgtype = 1 hash = 1
[499] dn = '8131111111' type = Extension xtype = DN cfgtype = 1 hash = 1
[500] dn = '9891111111' type = Extension xtype = DN cfgtype = 1 hash = 1
[501] dn = '2281111111' type = Extension xtype = DN cfgtype = 1 hash = 1
[502] dn = '3231111111' type = Extension xtype = DN cfgtype = 1 hash = 1
[503] dn = '7376' type = RoutingPoint xtype = DN cfgtype = 4 hash = 1
[504] dn = '7377' type = RoutingPoint xtype = DN cfgtype = 4 hash = 1
11:17:28.432: DelImplicitMwiExtensionTables dn:7378 mailbox:
11:17:28.432: MWIMNGR:STOP: DN="7378", Type=1 - not monitored
11:17:28.432: MWIMNGR:STOP: DN="7378", User - not monitored
11:17:28.432: PRESMGR:STOP: DN="7378" - monitoring not started
[225] dn = '7300' type = ExtRoutingPoint xtype = DN cfgtype = 19 hash = 1
[326] dn = '7301' type = ExtRoutingPoint xtype = DN cfgtype = 19 hash = 1
[327] dn = '7302' type = ExtRoutingPoint xtype = DN cfgtype = 19 hash = 1
[328] dn = '7304' type = ExtRoutingPoint xtype = DN cfgtype = 19 hash = 1
[471] dn = '7305' type = ExtRoutingPoint xtype = DN cfgtype = 19 hash = 1
[472] dn = '7306' type = ExtRoutingPoint xtype = DN cfgtype = 19 hash = 1
[473] dn = '7307' type = ExtRoutingPoint xtype = DN cfgtype = 19 hash = 1
[505] dn = '7308' type = ExtRoutingPoint xtype = DN cfgtype = 19 hash = 1
[506] dn = '7309' type = ExtRoutingPoint xtype = DN cfgtype = 19 hash = 1
[507] dn = '7310' type = ExtRoutingPoint xtype = DN cfgtype = 19 hash = 1
[508] dn = '7311' type = ExtRoutingPoint xtype = DN cfgtype = 19 hash = 1
[509] dn = '7312' type = ExtRoutingPoint xtype = DN cfgtype = 19 hash = 1
[510] dn = '7313' type = ExtRoutingPoint xtype = DN cfgtype = 19 hash = 1
11:17:28.433: Tracking thread w/handle 1409283840
@11:17:28.4339 [ISCC] Transport message handler is set
  -- created: CRequest@4aee5e0 RequestRegisterAddress-TServer[-1]/1
11:17:28.434: $+TLIB:CTI:Unknown:0:0
  +++ CIFace::Request +++
    -- new invoke
11:17:28.434 Std 36225 Client 2(TServer): registration requested for DN (gcti::route) not in CME
    Parsed: RequestRegisterAddress
    Numbers: +<gcti::route> -<none>
    Status: parsed:1 queued:0 sent:0 acked:0 preevent:0 event:0 context:0 transferred:0
@11:17:28.4340 [0] 8.1.101.62 send_to_client: message EventError
(Link down or bad link specified)
AttributeEventSequenceNumber 0000000000000001
AttributeTimeinuSecs 434051
AttributeTimeinSecs 1428592648 (11:17:28)
AttributeErrorCode 109
AttributeErrorMessage 'CTI link is down'
AttributeThisDN 'gcti::route'
AttributeRegisterMode 0
AttributeControlMode 0
AttributeAddressType 4 (RouteDN)
AttributeReferenceID 1
AttributeClientID 2
11:17:28.434 Int 04545 Interaction message "EventError" sent to -1 ("TServer")
[/list]
Offline Fra
« Reply #2 on: April 10, 2015, 09:54:35 AM »
You've truncated the log file just right after SIP Server had printed out its config.
The link is still down at that moment, and it's unclear why, you should upload the full startup log.
Also, 'gcti::route' is a special resource, that error message is of no concern.
Fra
Offline TheVagab0nd
« Reply #3 on: April 13, 2015, 04:31:26 PM »
https://drive.google.com/file/d/0B-cqKJsQ47JcQzlqMi1USmRwV2c/view?usp=sharing
Please take a look at your convenience. I have uploaded the start up log.
All the other component upgrades worked as expected with no issues, except for sip server
Thanks in advance
« Last Edit: April 13, 2015, 04:38:16 PM by TheVagab0nd »
Offline Fra
« Reply #4 on: April 14, 2015, 08:20:13 AM »
Nothing to report on the startup, apart from:
[list]
[li]your IVR_TServer does not seem to connect[/li]
[li]are you sure your Trunk DN is configured correctly? This is what it's printed out:
[520] dn = 'ses.somecompany.com' type = Trunk xtype = DN cfgtype = 14 hash = 1 contact = 'sip:ses.somecompany.com@10.20.10.146:5060;transport=udp' refer-enabled = false oosp-transfer-enabled = true[/li]
[/list]
Have you checked the 'regular' log generated right after this start-up one? If you claim SIP Server can't connect to SES, something should be indicated in it.
Fra
« Reply #5 on: April 14, 2015, 12:35:52 PM »
What does SES sip logs say? Maybe a Wireshark capture can give you more details
Offline TheVagab0nd
« Reply #6 on: April 14, 2015, 04:03:53 PM »
Thanks for the suggestions folks. I have been scratching my head over those logs for a day or so now.
After changing the trunk config to use transport=tcp, it works for some reason. Not sure if it is some whacky network issue.
When running netstat -na | grep 5060, it never gives the udp port status as established.
Anyways, that out of the way, instead of trying to make IVR_Tserver work with the upgraded SIP_Server, I am going to migrate GVP to 8.1 as well, since that's how it's gonna end up (plus unrealistic deadlines...Shhhhhhh...)
For now, with the existing GVP 7.6 with upgraded sip server, the Iserver client is unable to pass DNIS.  :(
« Reply #7 on: April 14, 2015, 05:34:59 PM »
Migration to GVP 8 is not straight forward, you need to migrate (and rebuild from scratch) all IVR projects... Be aware of that. Legacy and compatibility of GVP projects was dropped q few GVP versions ago.
Sip Server should be able to send same info, tho maybe some adjustments may be needed as SIP server 8 has more options and control than 7.6 did
Offline TheVagab0nd
« Reply #8 on: April 14, 2015, 05:41:08 PM »
That is true. we shall see how it goes. Gonna be doing that for the next few days.
Might be some more questions along the way. :)
