" /> Genesys Composer - Genesys CTI User Forum
Author Topic: Genesys Composer  (Read 3570 times)
Offline Raja12398
Genesys Composer
« on: June 15, 2015, 01:33:35 PM »
Hi Experts,
I am new in  Genesys Composer. My client does not use composer. they use, ird for developing strategy. i though to install composer in my local machine..if i install composer in my machine and open the strategy..is it going to impact anywhere? i just wanted to see, how composer work..if i install composer in my machine, and open stategy using that..where we don't use composer..we use ird in our environment..what impact it can be? please provide ur suggestion.. i am new to composer.i know..this is very silly question..sorry for asking this basic question.
Raja
« Last Edit: June 15, 2015, 02:58:37 PM by Raja12398 »
Re: Genesys Composer
« Reply #1 on: June 15, 2015, 01:58:21 PM »
Are there the Orchestration server deployed? If no, the Composer is not necessary, because you cannot use appllication/strategies written in Composer for URS environment only.
Offline Raja12398
« Reply #2 on: June 15, 2015, 02:18:08 PM »
No sir..there is no ORS..so if there is no ORS, no use of composer..is it?
Thanks for your response..
Sarkar
« Reply #3 on: June 15, 2015, 02:18:39 PM »
No, there is not. IRD only
Offline Raja12398
« Reply #4 on: June 15, 2015, 03:28:04 PM »
Thanks a lot
Offline zafzef.mourad
« Reply #5 on: June 17, 2015, 02:41:03 PM »
Well...u can use Composer to create VXML callflow without using ORS.
« Reply #6 on: June 18, 2015, 12:20:50 PM »
And how URS will process it?
Offline postx
« Reply #7 on: June 20, 2015, 09:03:23 AM »
MCP will do it...
VXML => MCP
SCXML => ORS
So when selected "Voice only" project you can build VXML apps with Composer
This will work with URS & MCP, no ORS needed...
"Routing" or "Routing and Voice" requires ORS in the environment.
« Reply #8 on: June 20, 2015, 01:56:41 PM »
There are limits as it is a GVP project
You can't use any resource from URS. It is not the same.
