" /> Licensing Issue - Genesys CTI User Forum
Author Topic: Licensing Issue  (Read 3195 times)
Offline nomster123
Licensing Issue
« on: June 16, 2015, 01:18:31 PM »
I have a valid license file, i just installed FLEXLM/ LM TOOLS and it is successfully installed.
When i open the LM tools , i start to configure the service and make the service by providing the paths of lmgdr, license and log file. Then i save it, when I perform inquiry it says that license master is UP , that mean license file is  valid but the problem is when i look at the windows services, the LM service which i just made doesn't start and gives the error" It cannot run on your local machine, and it did not a timely fashion.
The reason I am doing all this is because I want to start the T-server with simulator, i even gave the valid license path in the license options of the T-server.
Please help
Re: Licensing Issue
« Reply #1 on: June 16, 2015, 01:28:42 PM »
What say FlexLM logs?
Offline nomster123
Re: Licensing Issue
« Reply #2 on: June 19, 2015, 08:09:14 AM »
Nothing in the logs. Service not working still
Just wanted to confirm if we give manually path of License file in the options tab in T-server, would it work? because i gave it still T_server not starting up and logs saying that its a license error
Re: Licensing Issue
« Reply #3 on: June 19, 2015, 08:10:13 AM »
Yes, you define physical path to the license file
Offline nomster123
Re: Licensing Issue
« Reply #4 on: June 19, 2015, 09:56:21 AM »
Yes flexLM isnt installed, so I gave the physical path in the T-server option, still it says licenseing violation etc and license error whereas the license file is correct
Re: Licensing Issue
« Reply #5 on: June 19, 2015, 10:20:43 AM »
It seems like the license file is incorrect (in case that defined path is correct)
Offline nonny
Re: Licensing Issue
« Reply #6 on: June 21, 2015, 11:45:18 AM »
Checked the host name and volume id?
Sent from my SM-N9005 using Tapatalk
