" /> Auto_Answer - Genesys CTI User Forum
Author Topic: Auto_Answer  (Read 2470 times)
Offline nomster123
Auto_Answer
« on: June 19, 2015, 08:24:23 AM »
From where do I uncheck Auto_Answer on the agents side in genesys 8.1?
Re: Auto_Answer
« Reply #1 on: June 19, 2015, 08:30:03 AM »
Depends on used PBX type and agent application. Be more specific or check the docs before create a rookie topic
Re: Auto_Answer
« Reply #2 on: June 19, 2015, 02:12:50 PM »
Detail your environment
Offline nomster123
Re: Auto_Answer
« Reply #3 on: June 19, 2015, 04:40:50 PM »
Yes, its genesys framework 8.1 , so the problem is that I have set auto_answer to false in the interaction workspace configuration options..
But still it isnt working, all calls through simulator are automatically answered in the IWS. T-server is Avaya_CM. Do i  need to make any other change in Places, DNs, or T-server or anything to disable automatic answer by agent. please help
Re: Auto_Answer
« Reply #4 on: June 19, 2015, 05:43:33 PM »
Avaya is the key, ask them to disable it
