" /> busy prompt on SIP Server - Genesys CTI User Forum
Author Topic: busy prompt on SIP Server  (Read 2375 times)
Offline nonny
« on: June 30, 2015, 10:03:55 AM »
Hi guys
I've probably overlooked something simple but I have an issue where I do not get a busy tone played out in the following call flow scenario:
PSTN=>CUBE=>SIP Server=>Busy DN (either internal or an externally routed one).
I just get silence on busy.  Looking at the SIP Server deployment guide it has:
[b]busy-tone[/b]
Default Value: music/busy_5sec
Valid Values: Name and path of any valid audio file
Changes Take Effect: Immediately for all new calls
In this example, is busy_5sec the name of the folder, and if so what should the actual filename be?  I also assume this music folder should be in the install folder for SIP Server and not MCP for msml.
If I make the call via MCP by first routing to an IVR profile and vxml app I get the MCP busy audio fine.
If it's relevant I'm also not always hearing the dialing/calling tone either when a call is being transferred or dialing through to the destination DN.
Re: busy prompt on SIP Server
« Reply #1 on: June 30, 2015, 10:10:22 AM »
SIP cannot play anything, because SIP is just B2BUA without any RTP relation. All media services are provided by MCP itself. Check your configuration and option sip-busy-tone on trunk objects.
music/busy_5sec is a tone definition, which is saved within QTMF file under MCP_install_folder/music. All is described within documentation.
