" /> How to transfer a call to a Agent Group using the SDK? - Genesys CTI User Forum
Author Topic: How to transfer a call to a Agent Group using the SDK?  (Read 1953 times)
Offline HeavyStorm
« on: July 14, 2015, 08:26:35 PM »
Hello all,
I'm using the Genesys Platform SDK to create a customized softphone. I'm trying to transfer a call to a [b]group of agents [/b] thru the SDK.
[list]
[li]It's my current understanding that the object I'm looking into is an Agent Group, but it's my guess that it could also be a queue.[/li]
[li]Right now, I can do transfers to individual agents by looking up their DN (they are either catalogued or retrieved through the Stat Server).[/li]
[li]I use the RequestMuteTransfer to do so.[/li]
[/list]
Thanks for any help.
Re: How to transfer a call to a Agent Group using the SDK?
« Reply #1 on: July 14, 2015, 08:39:30 PM »
You don't transfer to an AG directly. You transfer to a Routing Point and it will follow your business logic.
Enviado de meu C6602 usando Tapatalk
