" /> Call by Skill report Genaration - Genesys CTI User Forum
Author Topic: Call by Skill report Genaration  (Read 2215 times)
Offline ajithmurary
« on: July 15, 2015, 01:54:56 PM »
Hi All,
I am not able to figure how to generate a report which shows me calls by skills
In our  environment we route calls using skill base routing and use virtual queues
There is infomart in our environment
I am not sure what keys to join in an sql query .
I am using toad to access the db
Please help me
thanks
Offline nonny
Re: Call by Skill report Genaration
« Reply #1 on: July 16, 2015, 05:34:34 AM »
Out of the box Info Mart/Interactive Insights reports should show calls sent to/through VQs, provided you have actually used those VQs in your routing.  Are you seeing any calls at all in Interactive Insights for VAGs?
Offline ajithmurary
« Reply #2 on: July 16, 2015, 01:10:23 PM »
we are using VQ for routing but dont use interactive insights
just use TOAD to access Infomart schemas
just looking for a clue  fro a script to map all the calls by skill
« Reply #3 on: July 17, 2015, 07:45:06 AM »
What is your current SQL query for these purposes? It depends on your GIM configuration, especially on what KVP are you collecting, etc.
