" /> WFM account - Genesys CTI User Forum
Author Topic: WFM account  (Read 3161 times)
Offline Leonxxx86
WFM account
« on: July 31, 2015, 01:40:35 AM »
Hi All,
Could someone please help? I'm stuck here, I have created a user (agent) in Person folder in CME and trying to created the same login but in WFM, Genesys giving me an error (error code: SCEE011) which is the duplicate account. How do I avoid this? Thanks
Offline nonny
Re: WFM account
« Reply #1 on: August 01, 2015, 01:54:14 AM »
Why are you trying to create the same login in WFM?  Couldn't you just assign the person that's already setup in CME to a role in WFM?
Sent from my SM-N9005 using Tapatalk
Offline Leonxxx86
Re: WFM account
« Reply #2 on: August 02, 2015, 11:35:03 PM »
Thanks nonny for your reply, I want the user to login to WFM and IWS with the same login credentials. I can see here in CME that a few users have the same login but I dont know how that has been done.
Offline nonny
Re: WFM account
« Reply #3 on: August 03, 2015, 08:47:10 AM »
Read up on sync via WFM configuration utility... I believe it may be in the help of the utility as well.
Offline Shooter
Re: WFM account
« Reply #4 on: August 03, 2015, 02:09:11 PM »
Configure/put that user/person under correct role in WFM config utility. Post that you should be able to login with same credentials in CME and WFM.
