" /> Interaction Workspace CustomCommand - InteractionVoiceAnswerCall - Genesys CTI User Forum
Author Topic: Interaction Workspace CustomCommand - InteractionVoiceAnswerCall  (Read 3963 times)
Offline aravind_mano
I having implemented IWS customizable command for "InteractionVoiceAnswerCall". I have placed customized library in Interaction Workspace folder and it works well as expected in my development lab. However, It does not work in Lab 2. Is there any setting needs to be enabled inorder execute the customcommands? When i looked into logs i see the custom class is instantiated and read configuration settings. But, it does not entered into Execute() Method. Logs are provided below. Please help me to resolve this problem.
Lab2 logs: Has issue
[quote]
15-08-05 15:19:50.888 [            5] INFO  e.InteractionManager - Create a new interactionId 'Id000'
15-08-05 15:19:50.888 [            5] INFO  e.InteractionManager - [InteractionEvent] received InteractionId:Id000(new) Id:00AC0269C206A04E ContextState:Created Profile:Primary State:PresentedIn(EventRinging ReferenceId:None) RelatedId:? MediaType:voice Direction:In ThisDN:3122999 OtherDN:7314203475 CorrelatorData:
15-08-05 15:19:50.904 [.PCT.Invoker#2] INFO                  ESDK - Notifying [DN] 3122999 [Id] 00AC0269C206A04E [State] Updated [Method] Void ESDKInteractionEvent(Genesyslab.Enterprise.Model.Envelope.IEnvelope`1[Genesyslab.Enterprise.Model.Interaction.IInteraction])
15-08-05 15:19:50.919 [.PCT.Invoker#2] INFO                  ESDK - Voice strategy 'DeleteStrategy' Cannot identify channel from [Device] 3122999 [Tenant] Resources Event EventAttachedDataChanged [Exception] Sequence contains no matching element
15-08-05 15:19:50.919 [.PCT.Invoker#2] INFO                  ESDK - Voice strategy 'VoiceProtocolEventStrategy' [Dn] 3122999 Processing msg [Name] EventOffHook [EndPoint] US2_SipServer_Pri - tcp://gen-03.serverus.com:3000 Asynchronous message. No switch policy applies
15-08-05 15:19:50.919 [.PCT.Invoker#2] INFO                  ESDK - Cannot identify channel from [Device] 3122999 [Tenant] Resources Event EventOffHook [Exception] Sequence contains no matching element
15-08-05 15:19:50.919 [            18] INFO  ice.Voice.MediaVoice - [DeviceEvent] EventOffHook [voice, AgentId:3124001, US_SIP_Switch(3122999)]
15-08-05 15:19:50.919 [.PCT.Invoker#2] INFO                  ESDK - Voice strategy 'VoiceProtocolEventStrategy' [Dn] 3122999 Processing msg [Name] EventEstablished [EndPoint] US2_SipServer_Pri - tcp://gen-03.serverus.com:3000 Asynchronous message. No switch policy applies
15-08-05 15:19:50.919 [.PCT.Invoker#2] INFO                  ESDK - Cannot identify channel from [Device] 3122999 [Tenant] Resources Event EventEstablished [Exception] Sequence contains no matching element
15-08-05 15:19:50.935 [.PCT.Invoker#2] INFO                  ESDK - Notifying [DN] 3122999 [Id] 00AC0269C206A04E [State] Updated [Method] Void ESDKInteractionEvent(Genesyslab.Enterprise.Model.Envelope.IEnvelope`1[Genesyslab.Enterprise.Model.Interaction.IInteraction])
15-08-05 15:19:50.935 [.PCT.Invoker#2] INFO                  ESDK - Voice strategy 'DeleteStrategy' Cannot identify channel from [Device] 3122999 [Tenant] Resources Event EventEstablished [Exception] Sequence contains no matching element
15-08-05 15:19:50.935 [            1] INFO  ws.ToasterController - Add the interaction (Id000 InteractionVoice)
15-08-05 15:19:50.997 [            1] INFO  ws.CaseDataViewModel - CaseDataFormatBusinessAttribute (IsToast:True): '' [InteractionVoice: Id000/00AC0269C206A04E]
15-08-05 15:19:51.029 [            1] INFO  ToasterWindowCommand - ShowToasterWindowCommand
15-08-05 15:19:51.169 [            1] INFO  cture.ChainOfCommand - End of Execution of Chain of Command ShowToasterWindow ( 140.402 ms)
15-08-05 15:19:51.578 [            5] INFO  e.InteractionManager - [InteractionEvent End Processing] InteractionId:Id000 Id:00AC0269C206A04E (EventRinging ReferenceId:)
15-08-05 15:19:51.578 [            5] INFO                  ESDK - Handle [Invoking] [DN] 3122999 [Id] 00AC0269C206A04E [State] Updated [Method] Void ESDKInteractionEvent(Genesyslab.Enterprise.Model.Envelope.IEnvelope`1[Genesyslab.Enterprise.Model.Interaction.IInteraction])
15-08-05 15:19:51.578 [            7] INFO  e.InteractionManager - [InteractionEvent] received InteractionId:Id000 Id:00AC0269C206A04E ContextState:Updated Profile:Primary State:PresentedIn(EventAttachedDataChanged ReferenceId:None) RelatedId:? MediaType:voice Direction:In ThisDN:3122999 OtherDN:? CorrelatorData:
15-08-05 15:19:51.584 [            7] INFO  e.InteractionManager - [InteractionEvent End Processing] InteractionId:Id000 Id:00AC0269C206A04E (EventAttachedDataChanged ReferenceId:)
15-08-05 15:19:51.584 [            7] INFO                  ESDK - Handle [Invoking] [DN] 3122999 [Id] 00AC0269C206A04E [State] Updated [Method] Void ESDKInteractionEvent(Genesyslab.Enterprise.Model.Envelope.IEnvelope`1[Genesyslab.Enterprise.Model.Interaction.IInteraction])
15-08-05 15:19:51.585 [            7] INFO  e.InteractionManager - [InteractionEvent] received InteractionId:Id000 Id:00AC0269C206A04E ContextState:Updated Profile:Primary State:Connected(EventEstablished ReferenceId:None) RelatedId:? MediaType:voice Direction:In ThisDN:3122999 OtherDN:7314203475 CorrelatorData:
[color=red]15-08-05 15:19:52.882 [            1] INFO  in.AnswerCallCommand - AnswerCallCommand: Config parameters loaded
15-08-05 15:19:52.883 [            1] INFO  in.AnswerCallCommand - AnswerCallCommand: Params: Telephone1=ani[/color]
15-08-05 15:19:53.033 [            7] ERROR ice.InteractionVoice - [.Dispo.DC.] The Business Attribute :'DispositionCode' is Empty
15-08-05 15:19:53.111 [            1] INFO  tructure.ViewManager - Cannot find the region 'CaseViewButtonRegion'
15-08-05 15:19:53.117 [            1] INFO  ws.CaseDataViewModel - CaseDataFormatBusinessAttribute (IsToast:False): '' [InteractionVoice: Id000/00AC0269C206A04E]
15-08-05 15:19:53.267 [            1] INFO  tructure.ViewManager - Cannot find the region 'CaseViewButtonRegion'
15-08-05 15:19:53.283 [            1] INFO  ws.CaseDataViewModel - CaseDataFormatBusinessAttribute (IsToast:False): '' [InteractionVoice: Id000/00AC0269C206A04E]
15-08-05 15:19:53.314 [            1] INFO  ws.ToasterController - Remove the interaction (Id000 InteractionVoice)
15-08-05 15:19:53.329 [            7] INFO  e.InteractionManager - [InteractionEvent End Processing] InteractionId:Id000 Id:00AC0269C206A04E (EventEstablished ReferenceId:)
15-08-05 15:19:54.048 [            5] INFO  DataWithDelayCommand - InteracationSetAttachedDataWithDelayCommand
15-08-05 15:19:54.083 [            5] INFO  cture.ChainOfCommand - End of Execution of Chain of Command InteractionSetAttachedDataWithDelay (  38.004 ms)
15-08-05 15:19:54.107 [.PCT.Invoker#2] INFO                  ESDK - Voice strategy 'VoiceProtocolEventStrategy' [Dn] 3122999 Processing msg [Name] EventAttachedDataChanged [EndPoint] US2_SipServer_Pri - tcp://gen-03.serverus.com:3000
15-08-05 15:19:54.108 [.PCT.Invoker#2] INFO                  ESDK - Cannot identify channel from [Device] 3122999 [Tenant] Resources Event EventAttachedDataChanged [Exception] Sequence contains no matching element
15-08-05 15:19:54.120 [.PCT.Invoker#2] INFO                  ESDK - Notifying [DN] 3122999 [Id] 00AC0269C206A04E [State] Updated [Method] Void ESDKInteractionEvent(Genesyslab.Enterprise.Model.Envelope.IEnvelope`1[Genesyslab.Enterprise.Model.Interaction.IInteraction])
15-08-05 15:19:54.120 [.PCT.Invoker#2] INFO                  ESDK - Handle [Invoking] [DN] 3122999 [Id] 00AC0269C206A04E [State] Updated [Method] Void ESDKInteractionEvent(Genesyslab.Enterprise.Model.Envelope.IEnvelope`1[Genesyslab.Enterprise.Model.Interaction.IInteraction])
15-08-05 15:19:54.121 [            8] INFO  e.InteractionManager - [InteractionEvent] received InteractionId:Id000 Id:00AC0269C206A04E ContextState:Updated Profile:Primary State:Connected(EventAttachedDataChanged ReferenceId:4) RelatedId:? MediaType:voice Direction:In ThisDN:3122999 OtherDN:? CorrelatorData:
15-08-05 15:19:54.121 [.PCT.Invoker#2] INFO                  ESDK - Voice strategy 'DeleteStrategy' Cannot identify channel from [Device] 3122999 [Tenant] Resources Event EventAttachedDataChanged [Exception] Sequence contains no matching element
15-08-05 15:19:54.162 [            8] ERROR ice.InteractionVoice - [.Dispo.DC.] The Business Attribute :'DispositionCode' is Empty
15-08-05 15:19:54.168 [            8] INFO  e.InteractionManager - [InteractionEvent End Processing] InteractionId:Id000 Id:00AC0269C206A04E (EventAttachedDataChanged ReferenceId:)
15-08-05 15:20:06.306 [            5] INFO  ptForEndVoiceCommand - PromptForEndVoiceCommand
15-08-05 15:20:06.312 [            5] INFO  eractionVoiceCommand - ReleaseCallCommand
15-08-05 15:20:06.368 [.PCT.Invoker#2] INFO                  ESDK - Voice strategy 'VoiceProtocolEventStrategy' [Dn] 3122999 Processing msg [Name] EventAgentNotReady [EndPoint] US2_SipServer_Pri - tcp://gen-03.serverus.com:3000 Asynchronous message. No switch policy applies
15-08-05 15:20:06.368 [.PCT.Invoker#2] INFO                  ESDK - Cannot identify channel from [Device] 3122999 [Tenant] Resources Event EventAgentNotReady [Exception] Sequence contains no matching element
15-08-05 15:20:06.370 [.PCT.Invoker#2] INFO                  ESDK - Notifying [DN] 3122999 [Id] ? [State] Updated [Method] Void OnNewEnvelope(Genesyslab.Enterprise.Model.Envelope.IEnvelope`1[Genesyslab.Enterprise.Model.Interaction.IInteraction])
15-08-05 15:20:06.382 [            7] INFO                  ESDK - [Agent] 3124001 (FQN=8b674a47-0aa5-41e7-b564-1493e1fcf9c5) Found Virtual Device '3122999' (FQN=f8446520-6641-44eb-8f9c-ee0993a18478)
15-08-05 15:20:06.382 [            7] INFO  ice.Voice.MediaVoice - [AgentEvent Begin] EventAgentNotReady AgentID 3124001 State:AfterCallWork  [voice, AgentId:3124001, US_SIP_Switch(3122999)]
15-08-05 15:20:06.382 [.PCT.Invoker#2] INFO                  ESDK - Voice strategy 'VoiceProtocolEventStrategy' [Dn] 3122999 Processing msg [Name] EventReleased [EndPoint] US2_SipServer_Pri - tcp://gen-03.serverus.com:3000
15-08-05 15:20:06.382 [            7] INFO  ice.Voice.MediaVoice - [AgentEvent] AgentID 3124001 New State:'NotReadyAfterCallWork' [voice, AgentId:3124001, JPR_SIP_Switch(3122999)]
[/Quote]
Lab1 Log: Working fine
[quote]
15-08-05 17:52:47.386 [            23] INFO  e.InteractionManager - Create a new interactionId 'Id000'
15-08-05 17:52:47.386 [            23] INFO  e.InteractionManager - [InteractionEvent] received InteractionId:Id000(new) Id:006E026BB9C22006 ContextState:Created Profile:Primary State:PresentedIn(EventRinging ReferenceId:None) RelatedId:? MediaType:voice Direction:In ThisDN:1001 OtherDN:1004 CorrelatorData:
15-08-05 17:52:47.432 [            1] INFO                  ESDK - No ChainRecord for interaction [ID] 006E026BB9C22006
[size=8pt][color=red]
]15-08-05 17:52:47.495 [            1] INFO  in.AnswerCallCommand - AnswerCallCommand: Config Params loaded
15-08-05 17:52:47.495 [            1] INFO  in.AnswerCallCommand - AnswerCallCommand: Params: Telephone1=ani
15-08-05 17:52:47.495 [            1] INFO  in.AnswerCallCommand - Execute AnswerCallCommand Main Thread
15-08-05 17:52:47.495 [            1] INFO  in.AnswerCallCommand - AnswerCallCommand: URL: http://localhost:5000?Telephone1=1004
15-08-05 17:52:49.573 [            1] ERROR in.AnswerCallCommand - AnswerCallCommand: Error while opening URL. Unable to connect to the remote server
15-08-05 17:52:49.573 [            19] INFO  cture.ChainOfCommand - End of Execution of Chain of Command InteractionVoiceAnswerCall (2078.414 ms)[/color][/size]
15-08-05 17:52:49.573 [            23] INFO  e.InteractionManager - [InteractionEvent End Processing] InteractionId:Id000 Id:006E026BB9C22006 (EventRinging ReferenceId:)
