" /> Agent login and logout time in CCA - Genesys CTI User Forum
Author Topic: Agent login and logout time in CCA  (Read 5493 times)
Zygis
I want to know when agent loggedin into the system and logout from the system with CCA.
What I have to do first?
Marked as best answer by on Today at 12:07:37 PM
John Doe
  • Undo Best Answer
  • Its not really using using CCA but this can be done by using the Stat Server table LOGIN. See p139 of the 6.1 Stat Server Users Guide.
    JD
    Zygis
    I know it, but I get information for all period, I want get only for one day. I Can't create template, in which I select only one day.
    Maybe You know, how create it?
    Actually, you can do it easily with LOGIN table.
    Look at page 143 of Stat Server User Guide: you have a Login table and there are several fields in it. The ones you would like to focus on are:
    Status, Time,AgentDBID
    When agent logs in, Stat Server writes the time when the agent logged in into Time field, writes '1' into Status and then writes Agent's CME ID in AgentDBID.
    When Agent logs out, Stat Server writes the time into Time field, '0' into Status field and Agent's CME ID into AgentDBID field.
    There are several things you should be clear about:
    1. Time is in UTC format. In other words, it is written as a number of seconds since 1970/1/1 12:00 . Don't ask me why they did it, but this is how it is, so you will need a function to convert from it into normal human time. (Ask me or anyone else if you need it)
    2. AgentDBID IS NOT Agent ID. It is a reference cfg_agentid or cfg_person table. Just find the same number in that table and then you will find your agent id.
    What are you using to see the results? Excel? Access? ...Brio?
    Actually Brio would be really simple. I am an engineer so I am not going to get into the licensing issues: I assume you have the license. :)
    Drop me a line if you want me to give you a sample Brio for agent login/logout reports.
    Zygis
    Yes, I have the license, and "Login" table we are using, I created a CCA report, and from this report I get statistic about agent status.
    Do You have a report about this statistic?
    Zygis
