" /> Cold Stand By Concept - Genesys CTI User Forum
Author Topic: Cold Stand By Concept  (Read 3850 times)
Offline Shooter
« on: September 10, 2015, 11:27:48 AM »
What is "Cold Stand By" concept in genesys and which application supports this stand by mode? I am unable to find any defination in genesys doc.
Adam G
Re: Cold Stand By Concept
« Reply #1 on: September 10, 2015, 12:51:53 PM »
Cold Standby is a collection of Server components which remain non-operational until started and configured, to act as a manual back-up for Primary or Secondary Servers.  It's generally used as a method of manual Disaster Recovery, with Hot Standby deployed as a first line of defense, for automated Business Continuity.
AFAIK, any Genesys Server component can be deployed as Cold Standby - but it has to be licensed too!
There are, I am sure, documents available on this type of deployment - perhaps you should look a little harder?
Offline Fra
« Reply #2 on: September 10, 2015, 02:18:57 PM »
[quote author=adamgill link=topic=9094.msg40762#msg40762 date=1441889513]
I disagree.
Where in theory you can deploy as many as 'standalone' components as you want, there are other limitations that won't allow you to have a cold standby configuration (e.g. think about associating two different T-Server to a single switch). Off the top of my head, only those application types that *don't* support warm/hot standby can be deployed in a cold standby configuration.
Secondly, I believe there is no licensing involved for cold standby, neither commercially, nor technically.
« Reply #3 on: September 10, 2015, 02:33:41 PM »
Agree with Fra
The cold mode is the most basic one, no Genesys layer is involved
Adam G
« Reply #4 on: September 10, 2015, 05:35:44 PM »
I am happy to be corrected... :)
Multiple TServers can be configured on certain types of Switches that have the capacity for more than 1 CTI Link.  The generic TServer config also allows for more than one set of "tcpip-link" settings, for multiple Switches, in different modes.
I will go away and do some homework, because my recollection of a Cold Standby was to allow for a Disaster Recovery site to be implemented and, if utilized, the components that need licences would need to be allocated.  On reflection, if it is Cold Standby, then the Primary (hot/warm) needs to have failed, for you to use it - and that would not incur extra licences.
I'm going to find some literature and amend my post... :)
Offline Shooter
« Reply #5 on: September 11, 2015, 11:05:33 AM »
Thanks all for your response  :)
Adam G
« Reply #6 on: September 13, 2015, 05:37:17 PM »
Seems as thought I opened a can of worms, doing my homework....
So, not everything is available as Cold Standby - and not everything is available as Hot or Warm Standby.
Is there are definitive list of these items, anywhere - showing what modes they actually do support?  Would be very useful to know!
« Reply #7 on: September 14, 2015, 03:21:08 AM »
Hot/Warm is based on each product, described on each deployment guide.
About Cold, no reference as is more an OS/manual task rather than Genesys one.
