" /> T Server Log files refining - Genesys CTI User Forum
Author Topic: T Server Log files refining  (Read 2099 times)
Offline Akshay3555
« on: October 19, 2015, 12:00:43 PM »
The T-Server logs are currently getting saved in a folder defined in the Config file in a server.
Could anyone please let me know how to automatically delete the log files which are 7 days old.
The logs which are 7 days old should be deleted from  the folder automatically.
The configuration is as follows.
<add key ="Days_for_Deletion" value="7" />
Kindly help if you know the solution.
Thanks in advance.
Adam G
Re: T Server Log files refining
« Reply #1 on: October 19, 2015, 12:18:29 PM »
Go to CIM/CME/Administrator and update your TServer>Options>log>expire setting.
Offline Fra
« Reply #2 on: October 19, 2015, 12:48:00 PM »
The solution you have in place - possibly a script which reads a config file and either it deletes or moves the log files somewhere else - is not a Genesys out-of-the-box functionality, so you should check internally with whoever created it.
Adam's is Genesys logs retention mechanism.
Fra
