" /> GIW Kpi stats - Genesys CTI User Forum
Author Topic: GIW Kpi stats  (Read 2792 times)
Offline alaint
GIW Kpi stats
« on: October 20, 2015, 02:32:46 PM »
We have a department that agents ask to use GIW MyStats Kpi for number and average time separatly for inbound and outbound calls.  Theses stats work for almost every use case, but not all.  Like this one : When an agent call a RoutingPoint to contact a senior agent of the same department, the call impact outbound stats for both agent.  But for the senior agent, we want to impact inbound stats.  Someone know if its possibly for an unique interaction to be outbound for one party and inbound for the other?  How?
Thanks.
Alain
Adam G
Re: GIW Kpi stats
« Reply #1 on: October 20, 2015, 05:14:52 PM »
Not sure how you come up with Inbound/Outbound call segments on an Internal call...?
Offline alaint
Re: GIW Kpi stats
« Reply #2 on: October 20, 2015, 05:40:59 PM »
[quote author=adamgill link=topic=9170.msg41258#msg41258 date=1445361292]
When agent A initiate the call, the interaction is tag CallOutbound and CallInternal.
When agent B receive the call, the call still be CallInternal but for this agent it is an inbound call.
As I said, I not sure its possible.  But as I dont know everything...
Thanks.
Alain
Re: GIW Kpi stats
« Reply #3 on: October 20, 2015, 06:19:25 PM »
On Tserver define what is business calls and test after that. Change will affect whole platform
Offline alaint
Re: GIW Kpi stats
« Reply #4 on: October 20, 2015, 07:42:56 PM »
[quote author=cavagnaro link=topic=9170.msg41260#msg41260 date=1445365165]
Default value are use, so a call on RP is already a business call.  Maybe I dont understand what you say to solve my issue?
Re: GIW Kpi stats
« Reply #5 on: October 20, 2015, 08:58:04 PM »
You wanna tell Tserver that internal calls to be considered as ACD ones.
Re: GIW Kpi stats
« Reply #6 on: October 20, 2015, 11:16:02 PM »
internal-bsns-calls is the option you would like to read more about
