" /> Problem starting G3 TServer - Genesys CTI User Forum
Author Topic: Problem starting G3 TServer  (Read 4535 times)
Hi, I was wondering if any one knows how to fix this problem:
Requesting PrimaryApp information...
not found
Requesting host information...
success (LCA port: 4999)
Requesting tenant information...
success (DBID: 101, name: Resources, password: (len=0))
Requesting switch(bydbid) information...
ERROR: switch(bydbid) object not found
FATAL: cannot continue missing Switch
Thu Apr 24 19:48:32 2003.740 Standard tomcat TServer_G3_test GCTI05062 Application ini
tialization failed, reason incomplete configuration
@19:48:32.7405 [5062] TServer initialization failed, reason [incomplete configuration]
(conn_cleanup) clearing timers...
...1 timer(s) cleared
...0 background timer(s) cleared
Obviously, I have switch assigned to Tserver and Tserver assigned to switch in CME.
The version for config server is 6.5.000.08
Marked as best answer by on Today at 01:01:14 PM
Ritchie
  • Undo Best Answer
  • Is config server running? Host information OK? Have you checked the DB to make sure the data is not corrupt? App and Switch name spelled correctly with no spaces?
    Not sure what else....
    Z
    Check Tenant and permissions
    gauthier
    Hi VIC,
    I've seen this problem before, I even think I found the answer in the forum but can't remember the title of the subject. Anyways you need to upgrade you config server. That should resolve it.
    Gauthier
    Kim
    I had a similar problem before.
    What we did was drop the current CME and then rebuild the whole thing. I recall that when we asked Genesys about it, we were told that if we use configuration wizard with CME on SQL server it is possible for our CME to get corrupted.
    Stephanie
    DITTO.
    We were using 6.5.000.08 with SQL server and we had our configuration manager environment get corrupted almost weekly. Upgrade. Upgrade. Upgrade.
    Haldane
    On the security tab in the tserver application make sure the user default and system are there. Then make sure both accounts exist on the security tab of the switch folder.
