" /> GVP > Nuance... - Genesys CTI User Forum
Author Topic: GVP > Nuance...  (Read 6070 times)
Adam G
GVP > Nuance...
« on: November 18, 2015, 04:39:14 PM »
I am being told by a client that their instance of GVP was built by Nuance (as an SI), like it was a dumb terminal IVR with TTS/ASR enabled.  I've tried to access the file sub-system/projects with Genesys Eclipse/Composer, but it is not loading .callflow elements, etc.
Is there such a thing a a proprietary tool from Nuance, which might have been used to build the CCXML/VXML for GVP?  If so, would that mean I need the same tools to develop the menus further - or is there a way to use Eclipse/Composer to develop the menus built by Nuance?
Hope I made the questions clear???
Thanks!
Re: GVP > Nuance...
« Reply #1 on: November 18, 2015, 04:54:12 PM »
  • What about "Nuance Café" product? From my real life experience I just know about tools for TTS/ASR configuration, tunning and developement. Not sure about VXML/CCXML.
    Adam G
    Re: GVP > Nuance...
    « Reply #2 on: November 18, 2015, 05:20:09 PM »
  • Really not sure - Nuance is not my thing.  If it's downloadable, I will certainly try it out!
    Thanks!
    Adam G
    Re: GVP > Nuance...
    « Reply #3 on: November 18, 2015, 09:45:49 PM »
  • Apparently, Nuance have "NDF" (Nuance Development Framework), which is another flavor for Eclipse - you can still use Eclipse but the elements, scripts, callflows etc. are packaged as jsp's, prior to expansion as (CC/V)XML.
    ...just in case anyone was curious! :)
    « Last Edit: November 19, 2015, 10:43:02 AM by adamgill »
    Re: GVP > Nuance...
    « Reply #4 on: November 19, 2015, 01:19:32 PM »
  • Great - thanks for posting it! Very useful for me.
    Offline livinginnj
    Re: GVP > Nuance...
    « Reply #5 on: November 23, 2015, 04:35:12 AM »
  • Nuance has framework  called SVF(2.0/3.0) which uses Nuance Dialogue Module to connect with DTMF/Voice. It is completely java and jsp's
    Adam G
    Re: GVP > Nuance...
    « Reply #6 on: November 23, 2015, 08:51:36 AM »
  • Interesting... does that Nuance Framework also contain the (TTS) tool set to create new audio files for inclusion in the ASR Call Flow?
    Re: GVP > Nuance...
    « Reply #7 on: November 23, 2015, 09:52:49 AM »
  • For TTS/ASR tools there is another tool, called Nuance Vocalizer Expressive Studio.
    Adam G
    Re: GVP > Nuance...
    « Reply #8 on: November 23, 2015, 12:21:43 PM »
  • Thanks - I shall go looking for it...
