" /> Virtualisation - Genesys CTI User Forum
Author Topic: Virtualisation  (Read 3271 times)
Offline vaunmac01
Virtualisation
« on: November 28, 2015, 10:03:08 AM »
Can't see an existing thread through the Tapatalk app on this.
What are people's experiences with putting Framework, Routing, GVP etc onto a VMWare environment?  Is there a good white paper out there that has spec recommendation (host spec, number of VMs per host, etc)?
Sent from my SM-N9005 using Tapatalk
Adam G
Re: Virtualisation
« Reply #1 on: November 28, 2015, 01:03:58 PM »
VMWare is supported throughout.  The specification details are available within the deployment guides for each element.
Offline shiningravi18
Re: Virtualisation
« Reply #2 on: November 29, 2015, 06:49:32 AM »
Yes VMWare is supported by genesys, In our environment each Genesys component is running on VM without any issues...
Offline nonny
Re: Virtualisation
« Reply #3 on: November 29, 2015, 08:11:38 AM »
Can you send me to the specification for virtual hosts/VMs?  I've checked deployment guide for SIP Server and see no mention of virtualisation.  Where can I find recommended ESX or other hosts recommended build specs?  As in how many VMs on each, which should be separate etc?  I've heard discussion that MCP/RTP traffic hosts should remain  physical.
Re: Virtualisation
« Reply #4 on: November 29, 2015, 09:26:33 AM »
I hope below document helps you  :)
http://www.vmware.com/files/pdf/techpaper/Genesys_Deployment_Guide.pdf
Adam G
Re: Virtualisation
« Reply #5 on: November 29, 2015, 10:26:27 AM »
[quote author=shiningravi18 link=topic=9233.msg41576#msg41576 date=1448789193]
Wow - an actual [u]useful document from Genesys[/u]... well, maybe not directly from Genesys... :)
Re: Virtualisation
« Reply #6 on: November 29, 2015, 04:08:06 PM »
Nice indeed
Thanks for sharing
Offline nonny
Re: Virtualisation
« Reply #7 on: November 30, 2015, 07:18:48 AM »
Yes, thanks!
