" /> IW_OverrideOptions - Genesys CTI User Forum
Author Topic: IW_OverrideOptions  (Read 3645 times)
Offline Leonxxx86
IW_OverrideOptions
« on: December 02, 2015, 02:23:46 AM »
Can you please advise what is the function of IW_OverrideOptions? I'm not able to find it in any doc and I can see it in URS logs? Thanks
Re: IW_OverrideOptions
« Reply #1 on: December 02, 2015, 07:36:02 AM »
I do not know where did you try to find it, but it is mentioned in several sources...from documentation (deployment guide -. section "Overriding Workspace Options - Modifying A Routing Strategy To Override Workspace Options Based On Attached Data"), on KB, website with documentation, etc.
Offline Leonxxx86
« Reply #2 on: December 03, 2015, 03:39:07 AM »
Yes, Thats the one i was looking for "Modifying A Routing Strategy To Override Workspace Options Based On Attached Data" thanks
Offline Leonxxx86
« Reply #3 on: December 03, 2015, 11:57:06 PM »
Can you please advise how the interaction.override-option-key= IW_OverrideOptions works? There is no enough examples in IWS doc on how the option work/override? Thanks
Offline Janis
« Reply #4 on: December 04, 2015, 06:07:28 AM »
I would advice to be patient, read slower and several times. There are things much more complicated and worst documentated in Genesys.
« Reply #5 on: December 04, 2015, 09:07:35 AM »
I do not think that this feature is described incorrectly, all what you want to know is mentioned there. Just follow the docs and read carefully.
