" /> Webservice Block In Routing - Genesys CTI User Forum
Author Topic: Webservice Block In Routing  (Read 2485 times)
Offline adnan.hassan@solveso.com
« on: December 03, 2015, 04:42:13 AM »
Hi All,
Following soap header is given by client.How I add timestamp in SOAP security block in IRD.
    <soapenv:Header>
  <wsse:Security>
        <wsu:Timestamp wsu:Id=""></wsu:Timestamp>
        <wsse:UsernameToken wsu:Id="">
            <wsse:Username></wsse:Username>
            <wsse:Password</wsse:Password>
        </wsse:UsernameToken>
      </wsse:Security>
  </soapenv:Header>
Regards,
Adnan
Offline terry
Re: Webservice Block In Routing
« Reply #1 on: December 03, 2015, 06:11:00 PM »
Unlikely you can customize SOAP Header element created with IRD web access block. The only option I think just manually compose and explcitely provide SOAP envelope content (by using Body parameter in Request parameters list).
« Reply #2 on: December 03, 2015, 07:29:36 PM »
That is something where ORS would be useful at
Offline eugene
« Reply #3 on: December 05, 2015, 12:11:35 AM »
Actually you can create custom headers i had a ticket with support on this.
basically create your own string variable xmlbody = ' your custom headers here'
then in your web service block you simply have literally the name 'Body' with your variable as the value.
hope that helps.
